Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2009, 07:33 PM   #1
PR1AWRet
CF Senior Member
Default How Much Sound Deadner (C5)
Next project is sound deadening the car. Yup should have done it when I installed the stereo and had everything apart. I searched and couldn't find an answer to how much it takes to do a C5. Basically most of the interior. I was thinking 120 sq ft of RaamMat BXT and 140 sq ft of Ensolite.
PR1AWRet is offline   Reply With Quote
Old 02-19-2009, 11:07 PM   #2
ilovemyredhotc6
CF Senior Member
ilovemyredhotc6's Avatar
I know Ant from Second Skin recommends 80-120 sq ft of damplifier pro to completely do the interior of the C6. Keep in mind that the DP is thicker and doesn't need to be doubled up at all like the RaamMat may need.
Quote:
ilovemyredhotc6 is offline   Reply With Quote
Old 02-20-2009, 12:31 AM   #3
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
Quote:
I agree. 80 will cover the critical areas. 120 will cover just about everything.
DP is awesome.
TheRadioFlyer97 is offline   Reply With Quote
Old 02-20-2009, 10:07 AM   #4
PR1AWRet
CF Senior Member
Thanks for the responses. I ordered the RAAMmat and Ensolite last night.
Old 02-20-2009, 10:57 AM   #5
Kale
CF Senior Member
Kale's Avatar
there's really no point in covering the entire car with mat.
Kale is offline   Reply With Quote
Old 02-20-2009, 06:29 PM   #6
fej
CF Senior Member
fej's Avatar
Rapp and listen (knock the panel/area in question). If it does not rattle, or resonate, you don't need to add additional material. We have fiberglass cars, which is a huge inherent advantage over your typical steel car.
Save some weight and $$$ and you could get it done with probably with 70 or less. I also like to ensolite product, I thought it made a measurable difference in my last truck install.
Key areas are the rear wheel wells and the rear hatch area. Most of the tub in the front cabin does not require a ton of deadening, or even full coverage to eliminate the resonance.
G'luck
Fej
fej is offline   Reply With Quote
Old 02-20-2009, 06:56 PM   #7
Kale
CF Senior Member
Kale's Avatar
Do a little test here.
Grab a plastic fork, and a metal fork.
Tap the metal fork's tines against the edge of something, and put it to your ear.
Tiiiiiiing! - That's what damping material stops.
Now take the plastic fork and tap its tines against the same something. Put it to your ear.
...Nothing? Try it again. No sound?
So... what does damping material do for a corvette?
I do highly reccommend damping the center tunnel of the car.
Old 02-21-2009, 11:31 AM   #8
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
Quote:
G'luck
Fej
I'm gonna do as you suggest and start with rear hatch and wheel wells.
Would you use Ensolite or Dynamat Extreme? Or something else?
Is FrostKing good enough for the wheel wells (trying to save a little weight)?
Thanks, Dave
Chevy-SS is offline   Reply With Quote
Old 02-21-2009, 11:54 AM   #9
PR1AWRet
CF Senior Member
The items I ordered above came to around $290. The weight is 58# for shipping. If you tell Rick you own a Vette, he will give you a discount. Saved about $27 on my order.
Dynamat Xtreme is a sound deadner like the RaamMat BXT. The Ensolite is a sound absorber, which goes on top of the deadner.
Old 02-21-2009, 12:14 PM   #10
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
Can you please post the materials details of your order (description, weights, part #'s and quantities)?
Old 02-21-2009, 03:36 PM   #11
VerTigo456
CF Senior Member
St. Jude Donor '08
VerTigo456's Avatar
Quote:
Also...post up pics of the project and let us know how the before and after goes!!
VerTigo456 is offline   Reply With Quote
Old 02-21-2009, 11:05 PM   #12
PR1AWRet
CF Senior Member
The before is at best, (2) 5.25 inch Kraco's playing in the car.
Here is his webpage for prices.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Old 02-27-2009, 09:48 PM   #13
VerTigo456
CF Senior Member
St. Jude Donor '08
VerTigo456's Avatar
You work on this project yet?
Old 02-28-2009, 07:44 PM   #14
KCvetteowner
CF Senior Member
KCvetteowner's Avatar
814 Motorsports
Hopefully a simple question..... Instead of spending $300-$500 and a lot of time to add sound deadening mat to the rear trunk area, couldn't you just make a partition out of the mat material/probably a couple layers thick that would block any noise from the trunk area for a lot less money???
KCvetteowner is offline   Reply With Quote
Old 02-28-2009, 07:50 PM   #15
fej
CF Senior Member
fej's Avatar
Not really, although partitions do help with tire/road/exhaust noise reduction.
Resonance is one of the main things you are trying to minimize/eliminate with deadening (hence the term). These products also help with outside noise reduction, functioning as another barrier between you and the outside world (and keeping your music inside your car as well).
For the Ensolite question, you need to add RaamMat as necessary first, and using a layer of ensolite certainly helps to reduce noise, but by itself it does not add any mass to the area it is applied to, so it offers no real reduction in resonance.
G'luck on the install
Rick at Raam is a really good dude
Fej
Old 03-06-2009, 10:09 AM   #16
PR1AWRet
CF Senior Member
Going to start installation this weekend.
Also, with a partition, the addition of a sub would almost me a moot point. A lot of the sound/bass wouldn't pass through.
Old 03-06-2009, 10:55 AM   #17
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
............Also, with a partition, the addition of a sub would almost me a moot point. A lot of the sound/bass wouldn't pass through.
Low frequency sound penetrates virtually anything. I've had subs in completely separated trunks (Lincoln Mark VII, for instance) and they sound great.
Old 03-06-2009, 09:20 PM   #18
PR1AWRet
CF Senior Member
Yes, you can feel the bass and hear it some. It does sound a lot better if its open.
Reload this Page How Much Sound Deadner (C5)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
