Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2009, 08:03 PM   #1
acarroll7715
CF Senior Member
acarroll7715's Avatar
Send a message via AIM to acarroll7715
Default C5 H/U install help
I decided to try and install my old Jensen 9510(yes I know very old indash) in my 03 Z06. I currently have the SVEN2 and the SVHGM4 harness. I'm trying to just add my h/u and retain my factory bose speakers/subs. The directions I am following are:
-Match all colored wires on the deck to the SVHGM4. Make sure to connect the remote/power antenna
-Set the SVEN2 to "Wired" on the input and output. Also making sure that both knobs are cranked fully clockwise
Does this sound correct? I read somewhere that the SVEN2 wont power if the preamp voltage less than 4. My jensen has a preamp ouput of 2 volts. Will I be ok and will the factory subs come on since I am not adding an additional sub? I tried searching but could only find an answer to this when someone was adding a sub and a h/u and the SVEN2 didn't work due to the lower voltage. Thanks!
acarroll7715 is online now   Reply With Quote
Old 02-18-2009, 08:09 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
wire it as stated
the svhgm4 is hit or miss works great for some works like crap for others, i never use the harness i just hardwire the sven2
i thought u set the output switch to rca but i can never remeber, try it both ways
pentavolvo is offline   Reply With Quote
Old 02-18-2009, 08:13 PM   #3
acarroll7715
CF Senior Member
Everytime I search I find something that contradicts something else! I'll just try it both ways. I didn't want to go through with the install only to find out that it wont power the stock amps due to my 2 volt output but it seems like it works fine for some?
Old 02-18-2009, 08:14 PM   #4
pentavolvo
CF Senior Member
pentavolvo's Avatar
as said wire it how it states ur 2 volt outpus have NOTHING to do with it
Old 02-18-2009, 08:16 PM   #5
acarroll7715
CF Senior Member
will do, lets hope the SVHGM4 works well for me
Reload this Page C5 H/U install help
Tags
c5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clutch pedal sticking theory GrantB C5 Tech 13 01-25-2005 07:13 PM
Does anyone have Andy's Head/Cam special? MagRed01Atty C5 Tech 17 05-19-2004 09:01 PM
Line in / iPod in my c5 + power. Got a couple questions after searching Slash Audio/Electronics 25 02-07-2004 02:58 AM
I have an 00 M6-Coupe...Please tell me the difference...thinking about trading ledfoot C5 Z06 Discussion 9 03-20-2002 06:38 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
