Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-05-2009, 08:46 PM   #1
beefcake
CF Senior Member
beefcake's Avatar
Send a message via AIM to beefcake
Default stereo works great.........until i close the driver door 08 c6
dropped my car off a few days at my buddies house while i was on vaca in fl,
called today, he said everything sounds great, backup camera is working got the dvd on a switch so it works while not stopped.
so, i get in the car, turn it on great, shut the door, sound is gone????
i've got an 08 bose with onstar, the stereo is an OEM with navigation.
when the door is open, everything works, sounds great
what could the problem be???
i did notice, there is a chime when the door is open also now which wasn't there. he said that is an option on the box,
i bought it used, but i don't think thats the problem as it's working fine, backup camera i bought works great with it too.
the only thing that doesn't seem to be working is the speaker on the blue tooth
i call out, they can hear me, but i cannot hear them
any input would be great, also, this came out of an 06 car i just looked it up in the for sale section, don't know if the adapter for the 06 is diff for the 08
beefcake is offline   Reply With Quote
Old 01-05-2009, 10:12 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
what interfaces did he use, this is important
pentavolvo is offline   Reply With Quote
Old 01-06-2009, 08:55 PM   #3
beefcake
CF Senior Member
beefcake's Avatar
Quote:
not sure what you mean by interface
Old 01-07-2009, 09:21 AM   #4
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
If you replace the head unit you need to use an interface like the Peripheral GMCO or GMAH24 to maintain proper functionality.
What I'm wondering is did you replace the head unit? You said it's OEM NAV and then you talk about DVD, which the OEM(factory) system doesn't support. If it's not factory NAV please give us the make & model. Did you install an amp?
It sounds like maybe your buddy skipped using an interface or used the wrong one or has the right one but hooked it up wrong. It sounds like in an effort to find a switched 12V circuit he tapped into the circuit for the lights that come on when you open the door. You close the door, the lights go off, the ACC power goes off and the head unit or amp shuts off.
TheKomoman is offline   Reply With Quote
Old 01-07-2009, 09:28 AM   #5
beefcake
CF Senior Member
beefcake's Avatar
this is the unit,
original entertainment media
http://www.oeradio.com/product_GM-5100.html
the stereo still works, the dvd still works, the back up camera still works, but no sound comes out of it once you shut the door
Old 01-07-2009, 10:28 AM   #6
1FUNC5
CF Senior Member
1FUNC5's Avatar
amp has lost switched power like stated above.....
1FUNC5 is offline   Reply With Quote
Old 01-07-2009, 10:33 AM   #7
beefcake
CF Senior Member
beefcake's Avatar
Quote:
so probably just one wire needs to be handled then more than likely i guess
he does all the installation at our ford store, but hasn't done many corvettes
i have to assume the amp is powered different than the head unit itself
i'm not very smart with this stuff
Old 01-07-2009, 10:53 AM   #8
TheKomoman
CF Senior Member
TheKomoman's Avatar
Quote:
Originally Posted by beefcake View Post
this is the unit,
OK - a question you need to ask this guy then - What brand and model of interface module did he use? It is REQUIRED when you replace the head unit.
If he can't answer that, he screwed up BIG.
Old 01-07-2009, 11:04 AM   #9
beefcake
CF Senior Member
beefcake's Avatar
by interface, i assume you mean the bose / onstar adapter?
i bought the stereo used off the forums here, it had everything with it already, so to be honest, i'm not 100% sure, it came out of an 06 which 05-08 call for the same adapter
Old 01-07-2009, 11:39 AM   #10
TheKomoman
CF Senior Member
TheKomoman's Avatar
Yes, that's the adapter/module I'm asking about. And yes 05-08 all use the same stuff and I'm fairly certain 09 does as well, but I don't have confirmation on that yet.
Did you keep the stock amplifier and speakers or did he install an aftermarket amplifier for you as well?
Old 01-07-2009, 11:51 AM   #11
beefcake
CF Senior Member
beefcake's Avatar
stock amp, stock speakers
Old 01-07-2009, 12:36 PM   #12
TheKomoman
CF Senior Member
TheKomoman's Avatar
Without specifics on what that adapter was and how exactly he hooked it up, we're throwing darts at a wall here. It sounds like you have what you need, so that means the likely problem is an install mistake.
Old 01-07-2009, 01:40 PM   #13
pentavolvo
CF Senior Member
pentavolvo's Avatar
plain and simple like said before if the radio is staying on but not the amp odds are u need to tie ur remote wire to somewhere else
Old 01-07-2009, 02:22 PM   #14
TheKomoman
CF Senior Member
TheKomoman's Avatar
Since he's using the factory amp the interface module should be taking care of that without the need to tie off any additional wire. That actually could be the mistake the installer made, using a wire switched by the door to trigger the amp.
Old 01-07-2009, 04:48 PM   #15
pentavolvo
CF Senior Member
pentavolvo's Avatar
i wonder what wire it is, could be a bad module also
i would try to bypass module and go right to amp turn on wire
Reload this Page stereo works great.........until i close the driver door 08 c6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
