Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2009, 08:01 PM   #1
chevyc6z51
CF Senior Member
Default Is there away around this??
Hi everyone i have two amps hookd up to my c6 with factory nav. Im wondering is there a way to have the amps stay on even if the car is not running( like if im in aux power mode?) Right now when i go into aux mode the amps turn off and only the bose amp stays on which means only 3 speakers are on. Is there a way around this? I did a search and couldent find anything any help would be great thanks everyone
chevyc6z51 is offline   Reply With Quote
Old 01-05-2009, 04:02 PM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
If you want it tied to RAP see if you can find a Peripheral GMRAP module. Its output is switched 12V and it reads the serial bus for the RAP signal to determine on/off. You use that as your amp trigger and you should be all set.
If all you want is it to run in AUX mode (as opposed to staying on until the doors are opened when shut off) then you just need to move the 12V trigger to a circuit that is on in AUX like the wiper circuit or heated seats, which are both in the passenger footwell.
TheKomoman is offline   Reply With Quote
Old 01-05-2009, 10:07 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
at the radio harness use the white wire from the big harness, this is teh wire the radio uses to turn factory amp on and off, this means ur amp wont turn off instantly when u turn radio/car off prly 45 second dealay or so, also when u unlock the car the amp will turn on as well
basically just use the white wire side effects shouldnt effect anything
pentavolvo is offline   Reply With Quote
Old 01-06-2009, 12:40 AM   #4
chevyc6z51
CF Senior Member
Do you happen to have any pics of this?? This sounds like what im looking for , so with the white wire you can make it work like it was from the factory?thanks for the help
Old 01-06-2009, 12:42 AM   #5
chevyc6z51
CF Senior Member
So to have run in aux mode like it did with the factory stuff i need to buy a part? I cant just wire into something? thanks for your help
Old 01-07-2009, 05:40 PM   #6
chevyc6z51
CF Senior Member
Ok i talkd to my installer and he said the white wire does nothing he was looking at it when he was thinking of away to tap into it to power up the amps in aux mode? Does this sound right do i need to buy a part to make it run on aux mode?thanks for any help
Old 01-07-2009, 06:02 PM   #7
TheKomoman
CF Senior Member
TheKomoman's Avatar
As I stated above, if all you want is an amp trigger then either use an add-a-circuit or just tie the wire off to the fuse in the wiper circuit. This is in the fuse box in the passenger footwell, just flip down the carpet to reveal it. There's a diagram there of the fuse boxes and it will show you which is the wiper. That is what I used until I swapped out for an aftermarket head so I know it works.
Old 01-07-2009, 06:14 PM   #8
pentavolvo
CF Senior Member
pentavolvo's Avatar
what i posted WILL work just did it
Old 01-08-2009, 12:18 AM   #9
HANNY
CF Senior Member
HANNY's Avatar
i just ran my remote wire from my amp to the heated seat fuse,that way whenever the radio was on in aux. the amp is on. pretty simple to do. I dont know where your insatller has it ran now but that would be a simple way. good luck
HANNY is offline   Reply With Quote
Old 01-10-2009, 08:36 PM   #10
chevyc6z51
CF Senior Member
thanks for all the help everyone. i talkd to my installer and he said he can do it but all so said that problems can come from this does this sound right?
Old 01-10-2009, 09:33 PM   #11
pentavolvo
CF Senior Member
pentavolvo's Avatar
ive been using remote wire that i just discovered on the radio in a few cars and no issues, also i have used the wiper fuse and no problems
Reload this Page Is there away around this??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How dirty is your car at this instant? 85RIT C4 General Discussion 49 05-19-2004 11:43 PM
Is there a spring under the clutch pedal? I think mine broke... Cobra4B C5 Tech 13 01-22-2004 05:19 PM
Is there any HP gain by switching to Electric rad fan? KJL C3 Tech/Performance 35 07-30-2003 05:42 PM
Is there anyway to fix the bose CD player without taking it out of the car? bhamvett C4 Tech/Performance 13 05-21-2003 11:09 PM
Is there a TSB for Throttle Body Whistle? DZ06 C5 Tech 9 12-29-2001 01:22 PM
is there a cheaper way to build this? QuickVet C3 Tech/Performance 10 11-04-2001 10:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
