Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2009, 04:27 AM   #1
NO1Z51
CF Senior Member
NO1Z51's Avatar
Default kenwood DNX5120 audio problem
I have a 07 C6 with a non-bose audio system. The car did not have navigation so I had the kenwood dnx5120 installed. After the install, the sound that I used to have was gone. It does not sound right at all. Before installing the unit, there was alot more bass. I have asked a few people and I was told that my subwoofer isn't working with the unit and the bass is just coming from the tweeters and speakers, not the actual subwoofer. I don't know if its a problem with wiring or just the unit itself. Does anyone know what the problem is here?
thanks
NO1Z51 is offline   Reply With Quote
Old 01-04-2009, 09:45 AM   #2
skamp
CF Senior Member
Quote:
thanks
If you do not have the BOSE then I think you only have the 3.5" speakers in the doors which would never give a lot of bass. The best thing to do is get a nice set of 6.5 comps and maybe a sub. I just swapped to 6.5" speakers in the front and it is simple.
Steve
skamp is offline   Reply With Quote
Old 01-04-2009, 01:15 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
bose or non bose u have door subs, should sound better with an aftermarket not worse
who installed it, did they bypass the amp etc
because they shouldnt have, with the right harness it should sound great
check and see if they turned the highpass filter on on ur radio its in one of the audio menus
pentavolvo is offline   Reply With Quote
Old 01-04-2009, 02:43 PM   #4
RanGer498
CF Senior Member
RanGer498's Avatar
pentavolvo is correct u do have door subs
as well as 3.5 speakers in the door anda total of 7 speakers in the car
1 in the center dash
4 up front (2 on each door)
2 in the rear
seems like whom ever did you system might have not used the harness or might have wired something up wrong .
if you can post picks of the work behind the radio mabe this can give others some insight on what could be wrong .
on a side note i just did mine with a kenwood unit as well and my sound is great ..!
RanGer498 is offline   Reply With Quote
Old 01-04-2009, 05:31 PM   #5
NO1Z51
CF Senior Member
NO1Z51's Avatar
What is required to improve sound? Do I just replace all the speakers with higher quality ones? What exactly needs to be done? I want to take it one step at a time. First I will replace all the speakers and hopefully improve sound and get enough bass. After that I will think about getting a sub and an amp installed. Will it sound bad if I just replace the speaker for now? And what is the cost?
Old 01-05-2009, 11:22 AM   #6
RanGer498
CF Senior Member
RanGer498's Avatar
first you need to fix what is wrong .
your sound shoud have been a little better after the Hu was installed ,i know mine was .
Old 01-05-2009, 03:14 PM   #7
Tull
Junior Member
Tull's Avatar
Send a message via AIM to Tull
Default Possible Problem
I had a similar problem, but in a C4. I have a Bose system and just upgraded to a Kenwood DDX512, which is the same unit as the DNX5120, but without navigation. I installed it this weekend and when running tests I only had audio when the AM/FM tuner was selected. Hang with me on this one, because it is relevant. I could not get audio from any other source. Video worked fine and so did pictures, but no audio.
On the C4 the Bose speakers are powered by individual amps for each speaker. I wanted to keep the Bose speakers for now, because they sound fine and I didn't want to tackle swapping out all the speakers right now. Got the right device (Scosche SLC4) to match the new unit to the Bose amplified speakers. Sounded great on AM/FM radio, but nothing on anything else.
Turns out my problem was I had used the motor antenna control signal (blue wire) to wire into the harness. So, when I was using the tuner the antenna went up and the Bose amps turned on. When I switched from tuner to another source, the antenna went down and the Bose amps turned off. Easy fix was using the power control signal (blue/white wire) in place of the antenna control wire.
I post all this to say that if your sound is fine with the tuner on, but lousy with any other source you may have a similar problem. If so, it is a very easy fix.
Tull is offline   Reply With Quote
Old 01-05-2009, 03:52 PM   #8
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Do you have chimes? If you lost your beeps & buzzers they didn't use an integration module like the Peripheral GMCO, this is required.
They may have done as Penta seems to be suggesting - wired the head unit's outputs straight to the factory speakers. This would lose you the subs for sure.
Either way, the answer is to hold your installer's feet to the fire and have them do the job correctly. Use a module like the GMCO, connect it up to the factory harness & the head and wire back in the factory connections to the speaker. All will work exactly as it should have in the first place.
I HATE lazy installers that make assumptions.
TheKomoman is offline   Reply With Quote
Old 01-05-2009, 04:05 PM   #9
RanGer498
CF Senior Member
RanGer498's Avatar
http://forums.corvetteforum.com/audi...some-help.html
Old 01-05-2009, 10:00 PM   #10
pentavolvo
CF Senior Member
pentavolvo's Avatar
agreed dont start replacing speakers till we figure out wtf is wrong
Old 01-06-2009, 11:34 PM   #11
NO1Z51
CF Senior Member
NO1Z51's Avatar
thanks for the inputs, ill let you guys know once i get it figured out.
Reload this Page kenwood DNX5120 audio problem
Tags
5120, audio, bose, c4, c5, corvette, dnx, dnx5120, factory, harness, install, kenwood, problems, scosche, slc4, speakers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
