Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-03-2009, 12:03 AM   #1
brasher801
CF Senior Member
brasher801's Avatar
Default Need a grounding spot in rear for amp C5
I am putting in two amps in the rear of a 2001. I need a place to ground them. Any ideas???????
brasher801 is offline   Reply With Quote
Old 01-03-2009, 12:19 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
i always run em to the factory ground near the seatbelts under side pillar, but u can drill to under car and ground on the frame rail
pentavolvo is offline   Reply With Quote
Old 01-03-2009, 02:20 AM   #3
Kale
CF Senior Member
Kale's Avatar
Kale is offline   Reply With Quote
Old 01-04-2009, 12:43 AM   #4
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
Depends on what you classify as "rear"
If you're on the rear wall. You can run them the cable through the rear to an OEM grounding point on the passenger side frame rail. (easy to see once you remove the passenger outside tail light)
If you're mounting in the front of the cargo area, the seat anchor bolts are a great location.
TheRadioFlyer97 is offline   Reply With Quote
Reload this Page Need a grounding spot in rear for amp C5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
