Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-25-2008, 04:09 AM   #1
CHEVY MAN 925
CF Senior Member
CHEVY MAN 925's Avatar
Default I need your help.
Hey guys, I'm looking at adding a sub to my vette. I currently have a jl audio 1000.1 amp and a 12w7 laying around. I want to use the amp but not the sub, reason being is the sub sacrifices to much space an its heavy. I'm looking at getting (1) Jl 13tw5 sub, can i use this with the amp? Also, can I place this behind one of the seats?
Should I dynamat the vette? I wouldn't want anything messing up the car!!! I would like to stay under $600 including installation. I found this deal http://www.dealercostcaraudio.com/jlaudio13tw5.aspx i figure i can use it to negotiate with a local shop. I also have a unopened jl audio amp wire kit.
Any help would be appreciated thanks.
CHEVY MAN 925 is offline   Reply With Quote
Old 11-25-2008, 06:23 PM   #2
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
You might be able to place the amp behind one of the seats... but you need to use a mounting board (1/2" or 3/4" MDF) between the car and the carpet. You will lose some leg room... but if that's not a problem for you then it's a possibility.
You won't be mounting a sub behind the seats unless you are 4' nothing and have the seat all the way forward.
You can use pretty much any sub with that amp. The big thing will be: can the sub HANDLE the power you deliver to it? It's always okay to have more power on tap than the sub can handle, so long as you are SMART about the gain settings and the volume knob.
Using sound deadening in our cars is one of the BEST things you can do to improve the overall audio experience. I won't say that Dynamat is better or worse than any other brand (Except EDead: Stay away!) but while you are looking at dampening material, look into sound absorption material as well. Closed cell foam does wonders for keeping out the noise... look for a product called "Ensolite" from RAAMaudio.
http://www.raamaudio.com/cgi-bin/index.cgi
(Rick is the owner of Rammatt and is also a Forum member! )
I used the spray-on adhesive that he sells (V&S) and it's the best stuff I have ever used. Very sticky stuff and easy to use. I haven't used his RAAMmat but I hear good things about it.
As for the cost... I couldn't tell you. I do all of my own labor and fabrication so I couldn't tell you what it would cost. A typical C5 box can cost about $150, but I build mine. A C6 box might be a bit more than that... take a look for a good deal here on the forum.
Figure that you will need an amp kit, the mounting board, pull the passenger seat and run the wiring, remove the radio bezel and hook into the stock head unit for a sub signal... that's a little bit of work. I wouldn't trust it with a shop that didn't know Corvettes, as many can attest to here. Odds are, if you are handy you can do it yourself with our help. You might even have someone close to you from here that can help out. It might cost you a frosty beverage or two...
Good luck.
Mark
Fasthotrod is offline   Reply With Quote
Old 11-25-2008, 06:33 PM   #3
Kale
CF Senior Member
Kale's Avatar
I'm not so sure damping material provides a benefit to plastic cars like it does metal cars.
Kale is offline   Reply With Quote
Old 11-25-2008, 10:57 PM   #4
CHEVY MAN 925
CF Senior Member
Good luck.
Mark
I'm 6'5 lol, thats why I figured the 13tw5 would proly fit? Also since I checked Jl audio site, they are having a sale. What i'm basically looking for is something that hits hard, clean, & clear. I would like to stay @ around $600 installed.
Old 11-26-2008, 01:55 AM   #5
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Quote:
It will NOT fit behind your seat and leave you any leg room. It's just not going to happen.
The JL 13TW5 requires a bare minimum of 2 & 9/16" depth and 0.8 cubic feet. Consider that a box would be made of 3/4" MDF and that puts you at 3 & 5/16" lost leg room. Minimum.
That means that you still need a box that is about 23.25" by 23.25" to meet the 0.8 cubic feet required for that sub. Unless you plan on some kind of false wall behind your seats that extends to the roof... I would rethink that idea.
If you have the skills, then you can do it for less than $600. Plan on working with wood, fiberglass, etc... If not, then look at the boxes that are available for your car. Boxology has some designed for a 10" sub... and you could go with a JL or another brand. (ID would be a good choice...)
If you wanted to go with that JL 13TW5 then you might consider building a false floor style box. It could be less than 4 inches deep, but extend across the rear cargo compartment and you could integrate the amplifier into the design. A nice cargo carpet from Lloyds would cover it, or build a custom grill/cover for the sub and amp.
A false floor will be heavy though... so if you have weight concerns then you'll want to look towards the cubby style boxes. (Like the ones that Boxology is selling in the other thread.)
Mark
Reload this Page I need your help.
Tags
12w7, false, forward, wall
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Who has the best price on the Varam cold air setup ? Steve-O C5 General 28 08-04-2005 12:53 PM
Mark on Vert. Top c2c4c6 C6 Corvette General Discussion 28 07-08-2005 07:53 PM
Major Problem, i need your help ASAP smdio C6 Tech/Performance 65 04-28-2005 09:09 PM
I need your help with some rotors! n2spd C5 General 16 10-28-2004 09:34 AM
I need your help on a legal issue concerning a paint job.... AEmedic C4 General Discussion 55 01-11-2004 01:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
