Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2008, 10:56 PM   #1
nzk
CF Senior Member
nzk's Avatar
Default HELP continuous loud hiss after "pro" install
had my system installed at a pro shop here in Dallas, well not so pro after all, they have no idea what theyre doing...
my system: boston mids/tweets in front, jl audio stealthbox, alpine pdx amp driving both the bostons and sub. stock HU w/ nav. all other speakers disabled. all items are brand new.
i have a continuous and very audible hiss coming from my passenger side tweeter whenever the amp is on. HU does not have to be on. engine does not have to be on. hiss does not change with volume or engine revs. its a very high frequency hiss that sometime crackles when music is playing, esp music with lots of bass. the amp is on whenever the car is on. when i first start the car no hiss. as soon as i turn on the HU, hiss is audible, and if i then turn the HU off, hiss continues.
some diagnostics i did on my own: with hiss going i disconnected the RCA inputs, still hissing. i swapped the speaker sides, hiss follows sides and is isolated to one single channel out on the amp (channel 2).
what can i do? i dont have time to take it back to the shop as its my daily driver and the hiss is giving me a headache. i took it back once already and they jacked around with it around the fuse box for a while and said thats just the way it is. i will take it back hopefully in 2 weeks but is there something simple i can do on my own to fix the problem?
nzk is offline   Reply With Quote
Old 11-21-2008, 11:35 PM   #2
65 Hardnoks
CF Senior Member
65 Hardnoks's Avatar
Does the amp have individual gains for each channel? If it does, try turning down channel 2.
They might have tuned it without noticing the balance was off on the HU and turned up channel 2 on the amp to even things out.
65 Hardnoks is offline   Reply With Quote
Old 11-21-2008, 11:41 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
bad channel on the amp prly, try swapping the rca's and see if the hissing follows an rca or not
pentavolvo is offline   Reply With Quote
Old 11-22-2008, 12:58 AM   #4
heavymetals
CF Senior Member
Support Corvetteforum!
heavymetals's Avatar
When you disconnect the rca's from the input the hiss didn't go away so that leaves the amp.
You don't say what model it is, but most models have seperate adjustments for gain and rolloffs (high or low) for each channel.
I would check there, and also see if they didn't reverse the crossover on that side.
__________________
03 C5 Z06 COUPE Maggied and getting modded to death
05 CTS-V SEDAN Maggied and modded to death
heavymetals is offline   Reply With Quote
Old 11-22-2008, 01:21 AM   #5
nzk
CF Senior Member
nzk's Avatar
sorry forgot to add i already tried turning down the gain. its the alpine pdx-4.100 model.
it only has 2 separate gains, one is setup for the mids/tweets (channel 1 and 2) and one for the sub (channel 3 and 4). neither gain has any effect on the hiss. even turned down all the way the hiss remains the same. crossovers are appropriate (HP for the mids/tweets and LP for the sub). the hiss is definitely coming from only channel 2.
Also an ipod adapter is installed as well, but doubt that has anything to do with it. even when i hook up the ipod no difference.
Old 11-22-2008, 01:25 AM   #6
heavymetals
CF Senior Member
Sounds like you got a bum amp.
Swap it out yourself.
__________________
Old 11-22-2008, 01:30 AM   #7
BOXOLOGY
Supporting Vendor
BOXOLOGY's Avatar
scienceofsoundinc@gmail.com
Bad Amp.
BOXOLOGY is offline   Reply With Quote
Old 11-22-2008, 10:13 AM   #8
355Spider
CF Senior Member
355Spider's Avatar
Take it to Arlington. There is a shop on S. Cooper near mayfield that does award winnng systems. They are excellent to say the least. I have used them for years. I can't remember the name for the life of me. If your interested PM me on monday and i'll get it.
355Spider is offline   Reply With Quote
Old 11-27-2008, 11:00 AM   #9
nzk
CF Senior Member
nzk's Avatar
thanks for the help guys! took it in and the tech confirmed it was the amp and replaced it. i guess even alpine makes a bum amp now and then. sounds great now!
Reload this Page HELP continuous loud hiss after "pro" install
Tags
alpine, amplifier, frequency, high, hissing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
