Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-09-2008, 09:43 PM   #1
08crm
CF Senior Member
08crm's Avatar
Default Is there a fix if I screwed up the stock 08 XM antenna ends??
I knew I should have looked for the directions on here before doing the XM to SIRIUS swap today but I figured I did it once already in another vette,so this should be easy.Well,I messed it up!The radio worked fine for a few minutes after install,sirius was on.Then I got a no antenna signal and then the radio stopped recognizing the module at all.It went only to AM/FM 1 + 2.When I put the XM back in it picked it right up.However the antenna ends are shot.Is there any fix for this??I'm totally depressed about this!I have no satellite at all now.
08crm is offline   Reply With Quote
Old 11-10-2008, 09:06 AM   #2
08crm
CF Senior Member
08crm's Avatar
Anyone?
Old 11-10-2008, 10:42 AM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
sorry dont have anything for you, idk if those ends can be repaired my understanding is they cant or atleast not without special stuff
pentavolvo is offline   Reply With Quote
Old 11-10-2008, 10:47 AM   #4
08crm
CF Senior Member
08crm's Avatar
Thanks.I'm looking into replacements now.How about the circuit board for the xm.Can it be moved to a different case?
UPDATE:GM actually has the replacement cables w/connectors available without buying the whole mirror!Now I have to get the box fixed!
Reload this Page Is there a fix if I screwed up the stock 08 XM antenna ends??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
A Tale Of 2 So Cal Dealers: Showcase Chevrolet (good) Versus Cormier (bad ) Chevrolet Gary Wells C5 Z06 Discussion 12 11-11-2004 10:25 PM
Pics of side scoops (non ZO6) 00hotvette C5 General 56 11-05-2004 07:30 AM
Totally hysterical... ski_dwn_it C4 Tech/Performance 95 08-19-2004 12:02 PM
Put my car on the Dyno at Mid America, results inside with pic of the sheet Paul G C4 Tech/Performance 13 09-24-2003 08:11 AM
I want a more comfortable steering wheel... Jay M C3 Tech/Performance 14 08-12-2002 06:55 PM
Is there anyone I can give my C4 to? caseyc C4 General Discussion 38 02-22-2002 05:46 PM
I have just about had it! - What would you do? bparker C5 Tech 30 11-12-2001 12:33 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
