Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2008, 03:59 PM   #1
techristian
CF Senior Member
techristian's Avatar
Default removed radio now flashers won't stop !
First off, this is going to be more than a 1 afternoon job.
I finally got my factory radio out of my C5 today and after summing up the situation I figured that I will continue tommorrow. I reconnected the battery and drove the car into the garage.
As soon as the battery was reconnected the 4 way flashers went off and would not stop. So I disconnected the battery again and called it a day.
When I go to put the new radio in will the flashers stop?
If not what else can I do to stop the flashers? Is this automatic with a battery disconnect-reconnect?
HELP!
Dan
techristian is offline   Reply With Quote
Old 11-08-2008, 08:58 PM   #2
techristian
CF Senior Member
Any ideas on this?
Old 11-09-2008, 12:18 AM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
did u damage the switch or snag the harness in some way, flashers are in no way tied to the radio
pentavolvo is offline   Reply With Quote
Old 11-09-2008, 01:31 AM   #4
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
the flasher wiring harness is behind the radio and routed to the driver's side (where your right knee is when sitting) If you accidentally pinched, pulled or otherwise messed with that harness when removing the radio, this would cause the flasher to freak out.
TheRadioFlyer97 is offline   Reply With Quote
Old 11-09-2008, 05:20 PM   #5
techristian
CF Senior Member
Thanks. The button has seemed to move. I only removed the lower console but perhaps the upper dash moved and is pushing the button down.
Dan
Old 11-10-2008, 07:33 AM   #6
techristian
CF Senior Member
Is there any chance that because the active handling control is unplugged from the center console that the flashers would go off? As instructed, the active handling control was unplugged to remove the center console.
Otherwise I may need to remove the entire upper IP cover to figure this out. I'm also checking the fuses.
Dan
Old 11-10-2008, 10:38 AM   #7
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
Dan
Sorry, you're going to have to go digging. Accessing the back of the hazard switch will require removing a good majority of the dash.
Old 11-12-2008, 09:16 PM   #8
techristian
CF Senior Member
Quote:
Got it fixed. I removed 3 upper dash bolts. I then moved it around a bit and was able to get my fingers in through the radio cavity behind the flasher switch. Then I pushed it forward back into place.
And I got a bit of a surprise as I began installation of the radio........
......continued at related link http://forums.corvetteforum.com/audi...8-harness.html
Reload this Page removed radio now flashers won't stop !
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
