Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-03-2008, 06:55 PM   #1
VETTEHIGH
CF Senior Member
VETTEHIGH's Avatar
Default Time it takes to replace power antenna in C4
Looking to replace my 1991 power antenna. How much time and work involved in doing so? Thanks
__________________
"THE TRUTH IS PLAIN TO SEE"
1991 C4 Conv - Auto - 383 SUPERRAM - 415~ RWHP: - 425~ RWTQ:
VETTEHIGH is offline   Reply With Quote
Old 08-03-2008, 07:38 PM   #2
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
Whole thing?? or just the mast?
Mast should only take 30min or so with a second person to help ( mainly due to the on off to run the antenna motor)
-=Jeff=- is offline   Reply With Quote
Old 08-03-2008, 07:51 PM   #3
VETTEHIGH
CF Senior Member
VETTEHIGH's Avatar
The complete power antenna. I can get a CORVETTE POWER ELECTRIC ANTENNA NEW DELCO GM for $115 brand new shipped
Old 08-04-2008, 01:29 AM   #4
RandyJ75
CF Senior Member
St. Jude Donor '06-'07
Support Corvetteforum!
RandyJ75's Avatar
At least a couple of hours. You will need to jack the car up, remove the rear wheel well to get to the antenna. Then you will need to spray the bolts that hold the car w/PB Blaster. Make sure the rear hatch is open before you disconnect the battery, you will need to trace the wires into the car.
Good Luck, Randy
RandyJ75 is offline   Reply With Quote
Reload this Page Time it takes to replace power antenna in C4
Tags
1984, 1991, antenna, antennae, c4, change, corvette, motor, power, remove, repair, replace, replacing, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
