Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2008, 08:40 AM   #1
pmuney
CF Senior Member
pmuney's Avatar
Default Need Some Help and Thoughts!!
Ok So C5, am changing my aftermarket headunit (from a Pioneer 4000ub to 5000UB, Long story). So I figure wire her up in my Lab, pop it in and let her rip... not so much. I have to remind you the ACC wire from the headunit has already been run to the correct power wire (because it worked before). So I check every wire on my wiring harness and it all looks good, check the headunit in another car, works fine. what the hell man... Why am I not able to get power to my headunit? Please if you have any ideas let me know, the only thing that has changed between installs is that I hooked up a Window Valet.
pmuney is offline   Reply With Quote
Old 08-03-2008, 01:44 PM   #2
pmuney
CF Senior Member
pmuney's Avatar
ttt
Old 08-03-2008, 07:14 PM   #3
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
as long as you have the ground, acc, and 12v constant powered by a source that has the correct amperage, it should work
scott_fx is offline   Reply With Quote
Old 08-04-2008, 12:50 PM   #4
pmuney
CF Senior Member
pmuney's Avatar
OK, I found out that the Yellow wire from the passenger side of the underdash that carries the 12V ACC, is not getting power, anybody know what fuse this is connected too? It is the Yellow wire from the 3 wire harness, I think the other wires are orange, and red or something. But the Yellow wire used to have power to it, and now does not.
Old 08-04-2008, 01:01 PM   #5
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
Fuse 11
pentavolvo is offline   Reply With Quote
Old 08-04-2008, 01:11 PM   #6
scott_fx
CF Senior Member
scott_fx's Avatar
Quote:
oh.. i totally misunderstood your post. i thought you were trying to hook it up in your lab and listen to it off of a power supply (not in the car)
Old 08-04-2008, 01:31 PM   #7
pmuney
CF Senior Member
pmuney's Avatar
YES!!!!! YOU ARE THE MAN PENTAVOLVO!!!!!! Fuse 11 was BLOWN!! I had to have pulled every single fuse in the panel, other then #11!! I wish I could repay you somehow man.
Reload this Page Need Some Help and Thoughts!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need some help with what to do, what to race???!!! LTC Z06 Autocrossing & Roadracing 44 07-07-2005 12:15 PM
My 1st vette...need some help ElCid C3 Tech/Performance 15 05-03-2005 05:07 PM
[CAM /IDLE ISSUES]Really need some help/suggestions here pewter99 C5 Tech 15 09-13-2004 04:39 PM
What would be the possible causes for this? I need some help. TuffShift C4 Tech/Performance 12 12-28-2003 11:28 PM
.32 away from my all motor goal need some help..... Phil97SVT C5 Tech 10 04-09-2003 01:05 AM
HELP!!! I NEED SOME INFO AND OPINIONS!!! mn_vette C4 Tech/Performance 9 03-27-2003 05:28 PM
I need some help........ GDaina Factory Correct Resto 24 12-08-2002 06:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
