Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-30-2008, 11:42 PM   #1
Snakecharmer383
CF Senior Member
Snakecharmer383's Avatar
Default My 89 install
Started yesterday doing the install with my buddy. I was 11-7 that night then came home to get the car and stuff and then started at about 8am. Obviously I was tired as heck but due to schedule friction we had to do it then.
Door panel off
Delco Bose gone
New HU JVC KD-AVX2
Infinity Reference 6022i with Adapter plate
The door was def. a pain in the a$$. You have to cut the actual door to get the 6.5 to fit. In my perfect world I wanted the oem grill to fit over the new speakers. After getting the speaker in, the grill wasn't even close to fitting over top of it due to the tweeter and the way the grill slants in. We are planning on modifying the grill cover and the tweeter to get it to fit, might have to build out the grill slightly.
I will post more pics as we go. I don't know when the next phase will be due again to schedules and weather.
__________________
1989 383
Fully ported alum. heads,stainless steel 2.00/1.56 severe duty valves,tpi valve springs, titanium retainer,forged speed pro pistons, 10.5:1 callies steel crank, 6.75" Dia. harmonic balancer,Hyd roller block,Superram plenum runner kit,Superram base,58mm throttle body,Hyd roller Tpi camshaft 219/219@50, 1.6 ratio stainless steel roller rocker arms,plasma moly speed pro rings,Hyd roller lifters,Hurst Line Loc
Best run: 11.85@119.65mph
http://temp.corvetteforum.net/c4/snakecharmer
Snakecharmer383 is offline   Reply With Quote
Old 07-31-2008, 02:51 AM   #2
RandyJ75
CF Senior Member
St. Jude Donor '06-'07
Support Corvetteforum!
RandyJ75's Avatar
Looks Good, how does it sound?
RandyJ75 is offline   Reply With Quote
Old 07-31-2008, 09:24 AM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
nice
pentavolvo is online now   Reply With Quote
Old 07-31-2008, 06:32 PM   #4
Snakecharmer383
CF Senior Member
I didn't really get to mess around with it too much and that's the only speaker that is in. So far tho. I love the HU.
Going to try to work on it again tom. morning.
__________________
1989 383
Old 08-02-2008, 01:42 PM   #5
Snakecharmer383
CF Senior Member
I hate PA
You can't keep any car clean here for more then 2 days in a row...my vette is still sitting tore apart!
__________________
1989 383
Old 08-07-2008, 09:47 PM   #6
Snakecharmer383
CF Senior Member
Worked on it this morning. Finally got the grill to fit onto door, major modding took place on the grill. Dremeled the heck out of the tweeter and pretty much removed all the support on the back of the grill. Used some apoxy on the edges for support on the grill. Just enough to let it flex but have some support.
Got the rear in on the pass. side so that side is complete. Sounds good, I'm happy..just have to do the other side now which is going to be tomorrow if the weather is good. Now that we know what to do it should go quicker. We did end up using 1/2" and 1/4" spacers on the door on the top 2 and 1/4" spacers for the bottom since the door is tapered.
The rear is pretty easy, removed the original bose junk then drilled 4 small holes for the 6x9 to mount too.
__________________
1989 383
Old 08-13-2008, 07:39 PM   #7
Snakecharmer383
CF Senior Member
Here is a couple more pics I took.
Rear with old bose out.
If you drill 4 small holes in the plate a 6x9 will fit right in.
Rear Infinity 6x9 (grill fits right over it)
__________________
1989 383
Old 08-13-2008, 07:41 PM   #8
Snakecharmer383
CF Senior Member
Sounds very good, I'm very pleased although I was scared at many times. I was at a car show and some people couldn't believe that it sound so loud with no amp.
__________________
1989 383
Old 08-18-2008, 03:47 PM   #9
Eakster
CF Senior Member
Eakster's Avatar
That looks identical to my rears! I ran them with the stock system for a couple of weeks before the other stuff went in. Now I have them tuned as subs. They give you a pretty good punch in the back, eh
Eakster is offline   Reply With Quote
Old 05-07-2009, 05:41 AM   #10
joshwilson3
CF Senior Member
I'm putting in new speakers and wire as well. Nice job!
__________________
1989 black/black auto coupe.
joshwilson3 is offline   Reply With Quote
Old 05-07-2009, 12:32 PM   #11
Shimy86
CF Senior Member
Shimy86's Avatar
Looks good. Those are the same speakers I run. If you like the sound with just the HU powering them you should hear them through an amp! I use an MTX 6304 and then an Infinity Baselink powered sub.....WOW. I used the Infinity grill covers for the fronts and backs, If you use the stock covers in front they are covering 30% of the speaker. Your carpet is dark, mine has the light grey so the infinity grilles looked okay as they were light grey also. I struggle with posting pic's but will get some so you can see what it looks like. Maybe you will like it??
Anyway, yours looks good, and I agree the doors were a PITA
Shimy86 is offline   Reply With Quote
Old 05-07-2009, 12:52 PM   #12
Kale
CF Senior Member
Kale's Avatar
Well for future reference, you could actually mount the speaker behind the mounting plate. IE, so the mounting ring is behind the mounting plate. Should be plenty of depth behind the speaker to pull it off.
Kale is offline   Reply With Quote
Old 05-07-2009, 05:44 PM   #13
joshwilson3
CF Senior Member
Quote:
How are you guys mounting 6x9" speakers in the rear bose mounting ring for an 89?
I took the bose pods out and did some measurement on the mounting ring, and noticed the holes for the 6x9" don't match the tabs for a 6x9" speaker. Did you guys drill new holes and use some clips to put the screws in? My mounting ring looks like the one in the above pic.
Anyways, I've got an Alpine HU, ran 16 gauge speaker wire, and was looking at installing Alpine SPS-69C2 50w RMS 6x9" in the back. There will be no amp, and it is hard to find 6x9" speakers less than 50w.
__________________
Old 05-08-2009, 01:12 PM   #14
Shimy86
CF Senior Member
Shimy86's Avatar
Here's the pic's of the speaker covers and others of my install
Old 05-11-2009, 06:15 PM   #15
Fiery89
Junior Member
Those speakers are what I've been looking to purchase as well! I'm just trying to find the best combo for a conv. setup and tricks to installing for the doors and rear.
I have and '89 vert and have removed the stock blose radio however wanted to see what the originals sound like with my new HU. I've connected the wiring for the speakers but am not sure on the antenna and amp wires for the stock speakers! My antenna does not go up however I should still hear sound from the speakers from the tuner. Instead, all I hear is a loud pop and some hiss and no sound. That pop comes from the left door. I'm not sure which wire to connect; the blue wire from the HU to the single red wire (amp power?) or the blue wire on the GM adapter plug in (from Crutchfield) . When I connect to just the blue wire on the adapter I hear a click noise from the "module" that's under the carpet (in the back) to which someone previously owned and wired the pos and neg wires into from the electric antenna motor. When I connect the wire from the HU to just the amp red wire, that's when I hear the pop and nothing.... There is also another single wire that I'm not sure what to do with that plugged into the stock radio. I see it in the picture above. The wire from the empty hole to the right.
So, you think I should go ahead and get the speakers and forget about the original ones? I did intend to replace the speakers but wanted to wait a little while longer so figure out if I wanted\needed an amp for them as well....
Fiery89 is offline   Reply With Quote
Old 05-12-2009, 01:18 PM   #16
Shimy86
CF Senior Member
Shimy86's Avatar
get the speakers, the bose amped speakers wont work with that HU
Old 05-12-2009, 06:30 PM   #17
joshwilson3
CF Senior Member
How are you guys mounting a 6x9" in this speaker ring as the mounting holes don't line up?
__________________
Old 05-14-2009, 09:00 PM   #18
RandyJ75
CF Senior Member
RandyJ75's Avatar
Quote:
Easy. Just use some large washers in the stock holes. The washers will hold the speaker in place. I used steel and nylon washers to protect the speakers.
Randy
Old 05-28-2009, 10:57 PM   #19
joshwilson3
CF Senior Member
On my 89 with the Alpine HU, I've got 4" speakers in the front bose pods. For the rear, I will have 6x9" 3-way Alpine speakers. All speakers will be run off the HU.
I don't have the rear speakers yet. But I hooked the front speakers up and cranked it to test the wiring. The front 4" speakers get a woofing sound that goes away when I turn the Bass all the way down.
So, that sounds like I need a Bass Blocker. What Hz Bass Blocker should I get? I read it is recommended to get a 160 Hz for the front, but I think that is when you are putting in 6.5" speakers in the door. Where as I'm using 4" in the Bose pods.
I was on Crutchfield and it says to go with 600 Hz Bass Blockers for low powered 4" speakers. So, should I go with the 600 Hz?
http://www.crutchfield.com/p_127BB60...f.html?tp=3216
__________________
Reload this Page My 89 install
Tags
6x9, adapter, bosemounting, c4, c5, corvette, cover, delco, depth, door, ii, leather, loc, panel, photo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Weatherstrip for my 89, any tips on how to do it right?? jzvette C4 Tech/Performance 26 05-07-2005 12:32 AM
well i did it!! two tone leather seats in my 89 vert lots of pics! 1989redvette C4 General Discussion 34 06-26-2004 12:59 PM
How can I make my '89 SLOWER! C10 JDR C4 Tech/Performance 25 07-09-2003 07:29 PM
My 89 still runs hot. WardVette C4 Tech/Performance 18 04-23-2003 08:37 PM
Want to install Ford injectors on my '89, but have some questions... TheCorvetteKid C4 Tech/Performance 9 04-17-2003 09:20 PM
My '89 keeps overheating - HELP!!! TheCorvetteKid C4 Tech/Performance 44 05-29-2002 12:34 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
