Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2008, 05:17 PM   #1
Shimy86
CF Senior Member
Shimy86's Avatar
Default alternator whine?? need help please
Okay guys, got a whine that is killing me. Where and what do I look for. Its an afternarket system, powered sub and MTX amp.
Let me know what else you need to know to help me out
Thanks!!!!
Shimy86 is offline   Reply With Quote
Old 06-25-2008, 05:24 PM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Thanks!!!!
It's a ground loop. Double check your grounds, though preferably there is a single ground point for all of the equipment. If your grounds looks good then you might want to try a ground loop isolator, plugging it inline on the RCA's. They can be had at Radio Shack.
TheKomoman is offline   Reply With Quote
Old 06-25-2008, 05:24 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
model numbers, how its hooked up, where your wires are ran, and where its grounded
pentavolvo is offline   Reply With Quote
Old 06-25-2008, 07:05 PM   #4
Homer3D
CF Senior Member
Homer3D's Avatar
Send a message via AIM to Homer3D
it could be bad wiring or the amp. My friend installed a kicker amp in his car and there was so much whine. We replaced it with a JL (same wires, just swapped amps) and the whine went away.
You could use a noise filter too..
http://www.allaudioexpo.com/nav/deta...gle&itemb=NS20
Homer3D is offline   Reply With Quote
Reload this Page alternator whine?? need help please
Tags
mtx, powered
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
