Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2008, 02:13 AM   #1
lexizpimpin
CF Senior Member
Default Gluing suede help
im trying to glue suede to wood i need suggestions on how to do this best for the glue not to bleed threw
and maybe i should be using different glue i got the 3m super trim adhesive super strenth thanks
lexizpimpin is offline   Reply With Quote
Old 06-26-2008, 03:32 AM   #2
SPL2k
CF Member
SPL2k's Avatar
Landau Top Adhesive. Must be sprayed with a paint / primer gun.
SPL2k is offline   Reply With Quote
Old 06-26-2008, 07:31 PM   #3
BOXOLOGY
Supporting Vendor
BOXOLOGY's Avatar
scienceofsoundinc@gmail.com
Quote:
+2
yellow (not red as I have seen it bleed through even vinyl)
use a rubber roller after the two surfaces are joined to keep it from lifting in high heat... GL
p.s. don't forget to wear a proper mask!
BOXOLOGY is offline   Reply With Quote
Reload this Page Gluing suede help
Tags
gluing, suede, wood
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
