Quote:
Originally Posted by Doubletap
Did you wire in a relay?
Looks like the Metra doesn't come with a relay for our application, and is probably the #1 reason folks have problems with the install.
Quote:
6. A Relay is needed in the 2005-2007 Corvette. You will need to cut the blue/white wire in half
between the 16 way Molex and 24 way gray connector.
• Connect the blue/white wire coming from the 16 way Molex to pin 85 of the Relay.
• Connect the blue/white wire coming from the 24 way connector to pin 30 of the Relay.
• Connect pin 86 of the Relay to Ground.
• Connect pin 87 of the relay to fused 12 volt constant wire. Using tape or a wire tie securely the
Relay from moving around in the dash.
The relay can be had at Radio Shack, something like this should do the trick:
http://www.radioshack.com/product/in...rt&tab=summary
The pin numbers referred to in those instructions are standard numbers for relays and not related to the GMOS-04.
