Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-23-2008, 05:10 AM   #1
Doubletap
CF Senior Member
St. Jude Donor '08-'09-'12
Doubletap's Avatar
Default Static noise after f900bt install gmah24?
Im getting static buzzing coming from the speakers. I have it all grounded under the hood. Even when the nav is off there is static like the amps on all the time. I wired up the gmah24 all speakers and chime module. no noise when I unhook the blue white wire. The chimes and onstar work. onstar was loud as till I turned it down. Car is a 08 no bose. Any ideas?
I check the ground a few times.
Doubletap is offline   Reply With Quote
Old 06-23-2008, 08:39 AM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Is it static like cracks & pops or is it alternator whine? The whine is unfortunately very common in our cars, the factory power source being pretty dirty noise-wise. If it's the whine then putting a ground loop isolator inline on the output of the Pio to the GMAH should knock that down.
http://www.radioshack.com/product/in...entPage=search
http://www.partsexpress.com/pe/showd...number=265-012
TheKomoman is offline   Reply With Quote
Old 06-23-2008, 04:50 PM   #3
Doubletap
CF Senior Member
Doubletap's Avatar
More like you have an amp on and the volume high with nothing playing.
does it with the radio off also comes out of all the speakers. it actually goes quite when i push onstar and it turns the red light on. then after onstar is off it goes back to static. does pop a little when the onstar voice is speaking.
Old 06-23-2008, 04:53 PM   #4
Doubletap
CF Senior Member
Doubletap's Avatar
It got quieter when i turned the volume down on the module for onstar..
I think im going to go get the gmos-04. and swap out the modules. might be better anyway because it has the vss and rear wires.
Old 06-23-2008, 08:42 PM   #5
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
gmos04 is garabage. do you have the remote hooked up so the amps are only on when the radio is on. id recommend ground loop isolators on the rca's i use them in every c6 just to avoid issues
pentavolvo is offline   Reply With Quote
Old 06-23-2008, 09:50 PM   #6
Doubletap
CF Senior Member
Doubletap's Avatar
Quote:
As remote hooked up you mean the blue white wire? Yea im gonna get some ground loop isolators. thats what it seems like that the amp stays on. how should i have the speaker wires connected? would i still get static when the nav is off? It should turn the amp off when i turn the nav off right? maybe only turn it back on when it needs to use onstar?
Old 06-23-2008, 09:54 PM   #7
Doubletap
CF Senior Member
Doubletap's Avatar
If i unhook the blue white the noise stops.
Old 06-23-2008, 10:14 PM   #8
Doubletap
CF Senior Member
Doubletap's Avatar
I think i might of figured out the problem. From reading other posts from u guys. I'll let u know how it goes.
Old 06-23-2008, 11:16 PM   #9
pentavolvo
CF Senior Member
pentavolvo's Avatar
the blue wire from the radio what does it connect to on the gmah24
Old 06-23-2008, 11:44 PM   #10
Doubletap
CF Senior Member
Doubletap's Avatar
solid blue goes to ant power. blue to blue is that right? blue white goes to amp on blue white on gmah24.
Old 06-23-2008, 11:54 PM   #11
Doubletap
CF Senior Member
Doubletap's Avatar
I had the speaker wires to speaker wires no rca just had the nav rcas empty. so im guessing that is it. lol. So now i will go rca ground loop rca and should be good to go right? I was just following the instructions. should i use female or male rcas to go to the ground loop isolators? Didnt make it to radioshack yet.
Old 06-24-2008, 01:08 AM   #12
pentavolvo
CF Senior Member
pentavolvo's Avatar
depends on your ground loop isolator and what ends it has on it
you should use the rcas
still sounds like ur amps not turning off with the radio
Old 06-24-2008, 01:36 AM   #13
Doubletap
CF Senior Member
Doubletap's Avatar
Yea, Im with you on that. guess ill see what happens after i get going with the ground loop isolators. Everything else was working just the hissing when the volume is down and the radio off. It would go away for a few seconds when the onstar activates and deactivates. all connections are soldered and everything. one other thing it was doing was playing the system beeps almost full blast everytime i would touch the screen. I turned down the vol on the module and the beeps decreased in volume. dont see why the nav sounds would be tied in to the module volume.
Reload this Page Static noise after f900bt install gmah24?
Tags
alternator, beeps, f900bt, gmah24, gmos04, instructions, loud, module, poping, static, whine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
