Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2008, 02:31 PM   #1
convertz
CF Senior Member
convertz's Avatar
Default Can I tap into the front subs to get a signal on a C5? (Results aith pics inside)
I have a diamond audio sub and PPI amp sitting around so, I'm thinking of putting it in the C5.
Without buying a fancy PAC adapter is it possible to get a signal from the front door speakers and run it through a level converter to get an RCA signal for the sub amp?
convertz is online now   Reply With Quote
Old 06-22-2008, 02:43 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
you could but god what it sound bad... you can tap the smaller harness behind the headunit for low level outputs
pentavolvo is offline   Reply With Quote
Old 06-22-2008, 02:56 PM   #3
convertz
CF Senior Member
convertz's Avatar
Any info or how to's on doing this? I looked and only found info for a C6, didnt think it was possible on a C5.
Old 06-22-2008, 03:13 PM   #4
pentavolvo
CF Senior Member
pentavolvo's Avatar
it is deff possiable... give me a few min and ill try to dig it up for ya
Old 06-22-2008, 03:33 PM   #5
pentavolvo
CF Senior Member
pentavolvo's Avatar
ok similar to the c6 you need to splice rca ends onto these wires, this is the smaller plug on the back of the radio
RF+ lite grn/blk
LF+ tan/blk
LR+ brn
RR+ dk blue
common lt blue
Old 06-22-2008, 03:35 PM   #6
convertz
CF Senior Member
convertz's Avatar
Awesome, and those are full range RCA outputs?
Old 06-22-2008, 03:41 PM   #7
pentavolvo
CF Senior Member
pentavolvo's Avatar
yes. if for some reason you have noise or are having issues try running the common to the radio chassis instead of the lite blue wire but u should be good to go
Old 06-22-2008, 03:44 PM   #8
convertz
CF Senior Member
convertz's Avatar
Thanks! Just saved me some $$ on that PAC adapter, and I hear they can have some serious roll off on the low end
Old 06-22-2008, 03:47 PM   #9
pentavolvo
CF Senior Member
pentavolvo's Avatar
yeah i assume since it has the rolloff on the c6 it must also have it on the c5. post your outcome and some pics
Old 06-22-2008, 06:06 PM   #10
convertz
CF Senior Member
convertz's Avatar
I'll post up pics/results as soon as I'm done. I'll probably be making a stealth box for the sub by next week.
Old 06-29-2008, 05:11 PM   #11
convertz
CF Senior Member
convertz's Avatar
Its all in and working. I need to get a few more feet of ground wire so I can move the amp to the back wall, and make all my connections final.
The sub still lives in a wedge box that just takes up space now, I have to build a stealth enclosure.
Getting line level from the headunit went well following pentavolvo's instructions. I ran enough RCA's for 4 channels but I only spliced in the rears. I took a few pics.
The harness behind teh head unit with the quick taps
The RCA cables I cut up and put quick connect ends on to get the signal. They run under the console and up over the waterfall right to where the amp is now. I'll probably have a signal processor behind the passenger they will run to later on.
Grounded the amp in the passenger side door post.
All connections made, put the radio in for a test run.
Old 06-29-2008, 09:22 PM   #12
pentavolvo
CF Senior Member
pentavolvo's Avatar
glad to know it worked well for u
Old 06-29-2008, 11:23 PM   #13
convertz
CF Senior Member
convertz's Avatar
Yup thanks again man!
Old 07-01-2008, 11:05 AM   #14
teddyca
CF Senior Member
teddyca's Avatar
This is all great info and should be placed in the C5 FAQ area. Thanks for the visual and all the info
__________________
2001 Millennium Yellow Corvette Z06 LOVE IT
ALL STOCK 500ishHP
2000 Millennium Yellow Corvette TOTALLED POS
NOT STOCK 420.15hp & 459.37tq
teddyca is offline   Reply With Quote
Old 07-01-2008, 11:07 AM   #15
pentavolvo
CF Senior Member
pentavolvo's Avatar
i will be doing a howto writeup with pics and there is also a harness available for liek 10 bucks that you just have to splice rca's onto so you dont have to touch factory wiring and u just plug harness in
Old 07-01-2008, 08:10 PM   #16
Phidelt076
CF Senior Member
Phidelt076's Avatar
Quote:
Which harness is this? I'm 2-3 weeks out from installing my system and would like to order this instead of splicing any of my factory wiring. I have read mixed reviews on the PAC adapter and had ruled this out.
Phidelt076 is offline   Reply With Quote
Old 07-01-2008, 09:35 PM   #17
pentavolvo
CF Senior Member
pentavolvo's Avatar
first off the pac adapter works great yes i realize they did testing on it in the c6 and found it boosting or cutting frequencies which im sure it does in the c5 as well, but with that said i used to use them in c5s all the time and never a problem
only place ive ever found the harness at and conveniently someone i order form a lot
http://www.sonicelectronix.com/item_...+ADD-VET1.html
you cut the one end off and splice the rca connectors in and then plug it in inline leaving only a remote wire to splice
Reload this Page Can I tap into the front subs to get a signal on a C5?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
