Sponsored by: DashLynx
Which wire to tap into for amp turn on signal
Old 06-14-2008, 12:10 AM
8mywal8
8mywal8's Avatar
Default Which wire to tap into for amp turn on signal
I have the stock Nav deck. Which wire is the remote turn on wire for an amp?
Old 06-14-2008, 10:49 AM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
there isnt one
you can tap a switched ignition line in the fusebox... either heated seat or i go into the 2nd smaller fuse box on the right side under the cover and tap the wiper fuse (there are 2 of them, i believe its the one that DOESNT say dwell)
Old 06-14-2008, 03:09 PM
AtomykC6
AtomykC6's Avatar
Default Accessory Power
I understand that there isn't an RAP option when you wire a new amp, but it seems there should be "accesory" level power somewhere in the fuse box. By this I mean, when you use the accessory setting on the start button, shouldn't you be able to get power? Right now, my Nav headunit is on, but of course, the aftermarket amps aren't.
Old 06-14-2008, 04:03 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
I have it on the wiper fuse circuit and the amp switches on in accessory mode.
Old 06-15-2008, 07:14 PM
pentavolvo
pentavolvo's Avatar
the fuse i listed is accessory
Old 11-15-2012, 04:59 PM
heheweec5
heheweec5's Avatar
could you take a pic of this and post it on here?
it would really help me out in identifying exactly how to have it set up
thanks
Old 11-15-2012, 09:25 PM
Fasthotrod
Fasthotrod's Avatar
Did you look in the C6 audio FAQ at the top of the forum? If so, you might have missed this:
NEW INFO - STOCK AMP TRIGGER WIRE IN HARNESS!! 3-17-2009
The white wire in B3 of the 24 pin harness will work as an amp trigger. It has a delayed turn off and early turn on so the factory amp is alive for chimes. This is only for if you are adding an amp to a stock head, if you put in an afermarket head use the amp trigger from that.
To Which wire to tap into for amp turn on signal
Quick Reply: Which wire to tap into for amp turn on signal
