Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-21-2008, 03:54 AM   #1
c5runs
CF Senior Member
Default Is my ED amp dead?
NINe.2X
I installed this amp for my sister about 1.5 yrs ago and it WAS working just fine. I had a chance a couple of weeks ago to take her car for a spin and to my surprise there was no bass from the sub. She didn't even realize this so I'm not sure when or how this happened .
I checked the fuse under the hood and the fuse on the amp and they all look fine. I got out the voltmeter to check if there was power going into the amp. Regarding the fuse holder on the power wire from the battery - from the battery to the fuse shows ~12V, after the fuse going to the amp shows no power ~1-2V. So there's no power going into the amp. I then took out the 2 fuses on the amp, now the voltmeter indicates ~12V power before and after the fuse from the battery. With the fuse back in the amp, it shows no power.
I not real good with audio stuff so this is really annoying to me. The amp is less than 2 yrs old. What should I look for or test out? Thanks for any help you guys can provide.
c5runs is offline   Reply With Quote
Old 05-21-2008, 06:42 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
IMO its not the amp but I could be wrong. It may be a loose connection and with the fuses in the amp it trys to draw power and thats why your voltage drops down to 1-2 volts because it cant get any current. Id check for solid connections at the amp, a solid ground, and open your fuse holder to check for solid connections and no corrosion going in and out. Worst case call ED they have good customer support and i bet you are still under warranty
pentavolvo is offline   Reply With Quote
Old 05-21-2008, 03:01 PM   #3
njvette98
CF Senior Member
Default check
check the remote wire that could be the problem
njvette98 is offline   Reply With Quote
Reload this Page Is my ED amp dead?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
