Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-20-2008, 02:41 PM   #1
znewton1
CF Senior Member
znewton1's Avatar
Send a message via AIM to znewton1
Default Using PDX 4.150 for Sub and 6.5 Components
I know this is possible. I will just bridge Channel 3/4 for the 10" 2ohm DVC that I am getting, and wire it in series.
Question is, I will want to turn the filter totally OFF on the amplifer, and use the high/low pass filter on the deck correct?
znewton1 is offline   Reply With Quote
Old 05-20-2008, 02:52 PM   #2
SRTstyle
CF Senior Member
The HP and LP filters on the amp and controlled independently for channels 1/2 and 3/4. You would still use the LP filter for the channels used to drive the sub.
SRTstyle is offline   Reply With Quote
Old 05-20-2008, 02:54 PM   #3
znewton1
CF Senior Member
znewton1's Avatar
Got it. Didn't see that. So that would make it work right?
Old 05-20-2008, 03:01 PM   #4
SRTstyle
CF Senior Member
Yes, 805Z06 did a setup very similar to this recently.
Old 05-20-2008, 03:46 PM   #5
Z28Johnny
CF Senior Member
Z28Johnny's Avatar
I've got basically the same set up on order. As stated, the amp can control 1/2 and 3/4 separately. You can still utilize your deck cut-offs though, just for extra measure.
I usually set the amp crossovers beyond where I want them, and use the deck to set it exactly, that way I have control from the deck if I want to do some fine tuning.
John
Z28Johnny is offline   Reply With Quote
Old 05-20-2008, 03:54 PM   #6
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
you can use either one or both
personally i always turn the Lowpass on for the sub at 150hz or so at the amp then set it where i want at the radio. this way if the radio gets reset you arent sending 1khz to the sub
pentavolvo is offline   Reply With Quote
Old 05-21-2008, 12:35 PM   #7
teddyca
CF Senior Member
teddyca's Avatar
Zach- I agree with everyone here. Since you are going with the Pioneer 8500bt you will have all the controls up front. I would set the 1/2 channels on the amp to Full pass and let the passive crossover from the componants and the deck do all the "fine" tuning. I would then bridge 3/4 and set the crossover to low pass and put it at about 100-120. Your going to want a bit lower freq. but control it at the deck to get precise. Better yet drop the car off and I will do it for you. Good luck buddy.
__________________
2001 Millennium Yellow Corvette Z06 LOVE IT
ALL STOCK 500ishHP
2000 Millennium Yellow Corvette TOTALLED POS
NOT STOCK 420.15hp & 459.37tq
teddyca is offline   Reply With Quote
Old 05-22-2008, 12:16 PM   #8
805Z06
CF Senior Member
805Z06's Avatar
Quote:
Let me know if you have any Q
805Z06 is offline   Reply With Quote
Reload this Page Using PDX 4.150 for Sub and 6.5 Components
Tags
4150, bridge, componemts, pdx
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
