Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2008, 05:05 PM   #1
openhelix
CF Senior Member
openhelix's Avatar
Default C6 rip n replace options
I've browsed through the FAQ and have some experience in car/home audio (and used to run a high end cables biz /flamesuit), however I'm a bit at a loss on what to do with the C6. I've decided on the Pioneer F900/F90 for the head unit and 99% sure I'm going to use a JLAudio stealth box. I need help filling in the rest. I'm starting from a stock/base C6 setup.
Should I replace the door speakers with 6.5" coaxials like the JL C5s or look at the nekid speaker panels and go the component route or do something else entirely? What are some good options for the preferred scenario?
Fair to say the center speaker gets taken out regardless of other factors?
Do I need a rear soundstage? I know this is somewhat of a religious war but I'd like some input. I would think it would be fairly simple and inexpensive to add some coaxial speakers in the rear area for midbass fill but no personal experience to back that up. speaker options?
Finally amp choices... Looking at the JL 300/4v2 for front/rear speakers and then, hmm something, to power the stealthbox.
Amp mounting. I really like this solution - http://forums.corvetteforum.com/show....php?t=2028908 Any other thoughts? I'd like to keep the amps out of sight and avoid having to use an amp rack in the hatch area. There's so little storage space as-is.
Thanks!!
openhelix is offline   Reply With Quote
Old 05-19-2008, 06:50 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
id ditch the rears and run a 4 ch to the frts and sub
pentavolvo is offline   Reply With Quote
Old 05-19-2008, 06:53 PM   #3
openhelix
CF Senior Member
openhelix's Avatar
Any thoughts on which speakers for the front? amp options?
Old 05-19-2008, 08:02 PM   #4
NYC6
CF Senior Member
NYC6's Avatar
Im a proponent of using rear fill speakers. " Wall of Sound " if you will. Its a real easy swap because the mounting points are there already. I have C5-650's in the fronts and XR-525's in the rears with a JL Stealthbox bringing in the lows. Im using a 450/4v2 and a 300/2v2 for the sub. I have a Kenwood 8019 headunit controling it all. It really sounds good. Some will argue about not doing rear speakers but I like it and so do all that hear mine.
NYC6 is offline   Reply With Quote
Old 05-24-2008, 09:28 PM   #5
toxin440
CF Senior Member
free bump you referenced my thread where I built my custom amp/cap holder behind the passenger seat, i feel honored that people like it
toxin440 is offline   Reply With Quote
Old 05-25-2008, 03:05 AM   #6
openhelix
CF Senior Member
openhelix's Avatar
thanks toxin. I'm actually going to use your design! Hope ya don't mind. I'm going to mount a 1F capacitor at the bottom them an Alpine PDX-5.
I ordered enough Canare LV-77S (100') and RCAP-77s (6) to run from the AVIC F900BT to the PDX-5. Planning to go with 12 awg speaker wiring.
I think I've decided on the Focal 130 CA1 for the rears then either the 165 KF or 165 KP for the fronts.
Reload this Page C6 rip n replace options
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
