Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2008, 03:54 PM   #1
rayosequis
CF Senior Member
rayosequis's Avatar
Send a message via Yahoo to rayosequis
Default '94 C4 Wiring Problem
In my '94, I replaced the factory bose head unit with a Kenwood using a PAC OEM1. The radio works great, however when I try to use the cd player, it does not work and I get no sound whatsoever. This is actually the second aftermarket head unit to have this exact same problem, so I concluded that the problem must be with the wiring.
After a call to PAC, the tech suggested that I may have gotten the power antenna lead and amp. lead mixed up causing the bose system amps to shut off when the cd player is turned on along with lowering the antenna.
Has anyone ever had a problem like this ? The tech did suggest that the wires are similar in color, blue/white vs. solid blue.
Thanks for any help or suggestions.
-Ernie
rayosequis is offline   Reply With Quote
Old 05-19-2008, 06:48 PM   #2
rayosequis
CF Senior Member
rayosequis's Avatar
After thinking about this a little more, do these Bose systems have a separate lead for the antenna ? Or is it always in the up position regardless of whether of not you are using the radio or cd player ?
If it's not separate, then that would explain everything...
Old 05-19-2008, 09:31 PM   #3
RandyJ75
CF Senior Member
St. Jude Donor '06-'07
Support Corvetteforum!
RandyJ75's Avatar
My Eclipse HU rasies and lowers the antenna according to what I am listening to; Up for radio, down for CD's and Sirius.
__________________
1990 Coupe, Sold
RandyJ75 is offline   Reply With Quote
Old 05-19-2008, 10:16 PM   #4
rayosequis
CF Senior Member
rayosequis's Avatar
Quote:
This is exactly what my Kenwood does, however, when the antenna goes down after switching to the cd player, it will emit no sound whatsoever.
After trying several different searches, I came across an old post in which the poster said that he read somewhere else that in the late '90's bose systems, the power antenna wire also sent a signal to the bose relays.
If this is the case, it would explain why the radio works, but the cd player will not as when it cuts power to the antenna it also cuts the signal to the relays.
Thanks for your response.
-Ernie
Old 05-19-2008, 11:45 PM   #5
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
you need to use the remote wire not power antenna wire. your antenna will stay up regardless of source but your bose amps will stay on
this is common in many cars not just vettes
pentavolvo is online now   Reply With Quote
Old 05-20-2008, 02:08 AM   #6
rayosequis
CF Senior Member
rayosequis's Avatar
Thanks for the confirmation ! Maybe this can be put in the FAQ somewhere ? You would not believe the trouble this has caused me, I practically gave away a very nice Pioneer 1.5 din because I had this same problem and assumed that the unit had a channel out.
Old 05-20-2008, 02:14 AM   #7
pentavolvo
CF Senior Member
pentavolvo's Avatar
sorry lol
i can see how it would be confusing as hell
Old 05-22-2008, 06:26 PM   #8
trowel4
Junior Member
trowel4's Avatar
do you have a wiring diagram? I have one in Haynes but it doesn't give positive and negative for speaker wires. tks
trowel4 is offline   Reply With Quote
Old 06-17-2008, 12:45 AM   #9
88c4stocker
Junior Member
88c4stocker's Avatar
so what exactly was the fix because this is the same problem I'm having...no sound on cd, radio sounds great...
I'm not getting my antenna to do anything though it stays down...?
I'm trying to install the HU in an 88/c4. Thanks for any info..
88c4stocker is offline   Reply With Quote
Reload this Page '94 C4 Wiring Problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C4 Bose help please, please, please jerryL98 Audio/Electronics 10 07-03-2005 11:35 AM
Gordon Killebrew and his C4 school: Comprehensive review (looong) The Example C4 Tech/Performance 18 08-20-2003 08:03 PM
new letter..EARLY BIRD ORDER DISCOUNT ON 2003 MANUALS..SEP 7,02 CorvettePartsBob Ken's Newsletters 10 10-02-2002 01:44 AM
Please help with spark knock. Especially anyone that has or has had a 85 C4 Duntov85 C4 Tech/Performance 22 09-14-2002 12:58 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
