Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2008, 01:35 AM   #1
MR.WaynesWorld
CF Senior Member
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Support Corvetteforum!
MR.WaynesWorld's Avatar
Location: The real question is; When you turn your car on, does it return the favor..
Send a message via MSN to MR.WaynesWorld
Default Tip with Kenwood 5120 and Kenwood CCD-2000 Reverse Camera
I just did an install of the Kenwood 5120 with the Kenwood CCD-2000 reverse camera. At the end of the install I had one issue. The 5120 has the ability to switch on the camera by pressing the NAV button for more then one second and everytime we did that we would get a blank screen. Put the car in reverse and it worked fine.
The HU has a line that goes back to the reverse lights and the Camera also has a line that goes back to the reverse lights. I also grounded the parking brake line from the HU to allow it to play vid's while car is in motion.
I was on the phone with Kenwood for over an hour trying to resolve the issue. According to Kenwood, wiring the system to their spec's it should work... But the means the parking brake line is connected to the parking brake switch.
While I was on hold we decided to cut the reverse line from the camera that ran to the reverse lights and BAM we had both camera in reverse and when the NAV button was pressed for more then one second.
I just wanted to pass along this info for anyone else that was going to install the same setup....
MR.WaynesWorld is offline   Reply With Quote
Old 04-25-2008, 01:37 AM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
this doesnt make any sense but ok
pentavolvo is offline   Reply With Quote
Old 04-25-2008, 11:39 PM   #3
MR.WaynesWorld
CF Senior Member
Quote:
I know it dosen't Greg but it works like it should... Even Kenwood was confused... Maybe having the parking brake line grounded is the key... I also mentioned it to Dennis and he was interested in it as well... All I know it fixed the problem and just wanted to put a heads up here for anyone else that maybe banging their head against the wall trying to do the same as I was doing....
Old 04-28-2008, 01:13 AM   #4
FactoryRaceCar
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
FactoryRaceCar's Avatar
Wayne is right. This install was done in my car and the head unit, blue tooth, Ipod, wiring and camera was installed by Wayne. We wired everything according to Kenwood diagrams but had this problem. Cutting the reverse line from the camera that ran to the reverse lights solved our problem. It took us almost 2 hours to figure this out. Even Kenwood level II tech was lost on this one.
This was just a heads up post for anyone else running into the same problem.
Thank you Wayne
FactoryRaceCar is offline   Reply With Quote
Old 04-29-2008, 07:59 PM   #5
c5 BearsFan
Supporting Vendor
c5 BearsFan's Avatar
Great info Wayne.
Must have something to do with all that bling in Noumans car
c5 BearsFan is online now   Reply With Quote
Old 04-29-2008, 09:41 PM   #6
FactoryRaceCar
CF Senior Member
Quote:
Originally Posted by c5 BearsFan View Post
Great info Wayne.
Old 04-29-2008, 09:42 PM   #7
MR.WaynesWorld
CF Senior Member
Thank you Wayne
No Problem Buddy... It was my Pleasure to do the install for you... I wish I would have had more time and more stereo stuff to install to give you a real killer sound system....
Old 04-29-2008, 11:24 PM   #8
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
good to know
DPG is offline   Reply With Quote
Old 06-13-2009, 07:50 PM   #9
txbikerdude
CF Senior Member
where did you mount the camera? i am thinking about doing the same thing
txbikerdude is offline   Reply With Quote
Reload this Page Tip with Kenwood 5120 and Kenwood CCD-2000 Reverse Camera
Tags
2000, 5120, c6, camera, ccd, ccd2000, instal, install, installation, installed, kenwood, photos, rear, reverse, spec, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
