04-19-2008, 04:52 PM
CF Senior Member
VSS Wire location, 2007 Corvette?
Does anyone know where the VSS wire is on a 2007 Corvette, Non-Bose, Non On-Star? Please help. Thanks
Also, Do I need to buy a wiring harness to Install my D-3? Would it make it easier? Which one? Thanks!
04-19-2008, 09:39 PM
CF Senior Member
try the dark green/white trace at the cluster or ECM, black plug, pin 57
04-20-2008, 12:51 AM
CF Senior Member
Cruise-In IX Veteran
instrument cluster is the way to go for VSS wire, not necessary for operation either
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
