Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-19-2008, 12:36 PM   #1
Spkrboy
CF Senior Member
Spkrboy's Avatar
Default Some Quick Sub Measurements
While I was setting up my test software/hardware to get after the measurements of Komoman's new speakers, I did some quick measurements of three subs.
A JL Audio 8W3v3 (8 ohms, red trace), ED 9kvD2 (4 ohms, green trace) and Vifa M22WR09-06 (6 ohms, pink trace) were all measured using identical drive levels for nearfield response. Notice how much better the Vifa is and how it can even be used as a midbass up to around 500 Hz. The ED should have had a substantial advantage in SPL because it had the lowest configured impedance, but it did really no better than The 8-ohm JL. Measurements are valid down to 30 Hz here.
And here are the JL and ED drivers in a 0.3 ft^3 box. There's still no advantage to the lower impedance.
Spkrboy is offline   Reply With Quote
Old 04-20-2008, 05:29 PM   #2
robvuk
CF Senior Member
robvuk's Avatar
Send a message via AIM to robvuk Send a message via Yahoo to robvuk
When you say identical drive level, do you mean identical voltage? Or power, based on the claimed impedance? Did you run an impedance plot? I see approximately 3db of difference below 80hz which would account for the impedance if they based the impedance claim in that bandwidth.
robvuk is offline   Reply With Quote
Old 04-20-2008, 05:45 PM   #3
Spkrboy
CF Senior Member
Spkrboy's Avatar
Quote:
Identical voltages. That's why there's no advantage to the lower-Z driver as it's getting twice the current. I did this as a quick example of why there's no need for people to be concerned with 4- vs 8-ohm speakers as some often worry about. Impedance plots were run way back when I did the first round of tests for these drivers.
The opportunity came up now for this comparison because I was setting up my test hardware and needed some known samples to verify all was in working order.
Old 04-20-2008, 05:52 PM   #4
robvuk
CF Senior Member
robvuk's Avatar
There's no difference in efficiency whether it's 4 or 8 if the motor assembly is the same. It's only a matter of convenience/preference for any particular install or optimizing amplifier power.
Reload this Page Some Quick Sub Measurements
Tags
m22wr09, vifa
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
