04-17-2008, 11:48 PM
CF Senior Member
Best Amp dor SQ? Audison/Alpine
I've heard many good things about both amps...
I'm looking at:
Alpine PDX 4.100 (4x100w @ 4 Ohms)
Audison SRX4 (4x60w @ 4 Ohms)
As for a little background info
Active crossover setup:
HU: Pioneer Premier DEH-P880PRS
Door Tweets: Seas 27TFFNCG (80w RMS @ 4Ohms)
Door woofer: Mach 5 MLI-65 (100w RMS @ 4Ohms)
Any thoughts/comment/opinions?
Thanks,
-Jason
04-18-2008, 01:04 AM
CF Senior Member
The PDX will run those speakers just fine. I'd go for the least expensive one that best fits your install.
04-18-2008, 08:33 AM
CF Senior Member
The Alpines I've heard are a bit harsh, but then again, that was driving a set of Focals. Swapping in an Xtant in place of the Alping PDX made a large improvement, so it was certainly the amp to an extent. I'd go with the Audison unless that much power is important to you, IMHO.
04-18-2008, 08:56 AM
CF Senior Member
Well...If it makes any difference, where i found them, there is only a $20 price difference between the two...
04-18-2008, 09:20 AM
CF Senior Member
04-18-2008, 10:51 AM
CF Senior Member
So you'd give up a bit of power (volume) to gain the sound quality of the Audison...Hmmm...
04-18-2008, 10:54 AM
CF Senior Member
Well, I can go with the Audison, and if the power is insufficient, I can bridge it and buy another two channel...
04-18-2008, 11:25 AM
CF Senior Member
Here are the specs:
The MLI-65 woofer:
Power Handling - 100 watts RMS (Maximum)
Sensitivity - 89db (2.83 volts)
Impedance - 4 Ohm (SVC)
The Seas 27TFFNCG tweeter:
Power Handling - 80 watts RMS (Maximum)
Sensitivity - 91db
Impedance - 4 Ohm
04-18-2008, 11:28 AM
CF Senior Member
Audisons are usually a little underrated. It should be fine.
04-20-2008, 06:23 PM
CF Senior Member
Damn, I just bought an Alpine PDX 5 to drive my Focals and JL Audio sub. I almost wish I would have seen this before I bought it.
04-20-2008, 06:31 PM
CF Senior Member
I have Audison LRX Series w/ stock nav/HU and it sounds really good.
04-20-2008, 07:01 PM
CF Senior Member
Quote:
Originally Posted by
craig9132
I dont think my PDXs sounded harsh at all. They did, however, sound different... Sort of like all of the speakers were closer together.
I prefer the sound of my new ARC KAR amps, but miss the alpine's efficiency.
04-20-2008, 07:06 PM
CF Senior Member
Kale
craig9132
My PDX sounds really good. It's small and very clean unit. The best part of it that it does not heat up, very efficient.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
