Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2008, 08:14 PM   #1
huillery
Junior Member
Default HELP how to take c6 door panels off?
l can get most of the door off but neer the door handle it wont budge?and if you can help do yo uhave any pics
thanks
huillery is offline   Reply With Quote
Old 04-01-2008, 08:25 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
there is threads out there to do this, check c6 faq
did you remove the bolt up by the door handle, i know on passnger side u have to pry off the little door open button and theres a bolt and on the drivers side there is one somewhere to
pentavolvo is offline   Reply With Quote
Old 04-01-2008, 09:25 PM   #3
TheKomoman
CF Senior Member
St Jude Donor '13
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Check my install thread, linked in my signature below. It includes door removing instructions.
__________________
1980 L-82 Dark Claret/Claret
2006 Z51 MN6 Monterey Red/Black/Ebony Convertible
2008 Z06 Velocity Yellow/Ebony
The Official Forum C6 Audio FAQ
TheKomoman is offline   Reply With Quote
Old 04-01-2008, 10:22 PM   #4
805Z06
CF Senior Member
805Z06's Avatar
Here is some info from my other thread. Just ignore the insulation part.
Removal & Insulation of Door Panels
This information might be beneficial to others if they decide on upgrade speakers or insulation of the doors.
The driver’s door
The first thing you want to do is raise the window up. Once you pull off the panel, you can’t raise the window and you won’t have access to the inner shell of the door.
Click the image to open in full size.
The driver’s door has a total of two bolts. They are located right below the door handle. If you look closely, you will see a small plastic cover. Remove the cover and you will see the two bolts. Uses the proper tools and remove the bolts, failure of using the proper tools may strip the bolts.
On the bottom of the door there is a little opening to pull the panel off. Just pull away at different positions. It’s going to sound like the door is ripping apart, but that’s from the plastic holders. Once you have the panel loose, don’t yank it out. There is one main cable harness that needs to be taken off.
Once you get to this point, you will see the exposed outer door shell. You will also see the 10” Bose woofer and a large rubber cover on the left side of the door. The rubber cover provides access to the inner shell of the door.
Remove the Bose woofer from the door. There is a little connector that you need to disconnect when the speaker is loose. Then you want to remove the large plastic cover on the left side of the door. Once all that is done, you will have partial access to the inner shell of the door. Do not remove any bolts on the outer shell of the door; these bolts hold the window system.
I basically covered of the inner shell of the door with Damplifer Pro and Luxury liner. It’s a tight squeeze but it’s doable with the speaker and rubber opening. That area took me about an hour or so to do. I then did the outer shell of the door with Damplifer Pro. This area is very hard to do and the surface is not flat. The outer shell took me 2-3 hours to do.
This pic shows an upgraded JL speaker and mount plate.
A WARNING – be careful not to insulate the edges of the door because they are exposed with the door panel on. I made this mistake on the outer shell and it took me a couple hours per door to clean up. Just insulate to the edge of the panel clips, basically leave at least one-inch strip around the door without any insulation.
The driver’s side has about 10-15 pounds of insulation. But, it is so solid and it shuts better than a Lexus, a nice thump. This will definitely improve the sound of the speakers.
Putting the door panel back is a partial PITA. On the top of the door panel, there are metal hooks. You want to put those in before pushing in the clips. It will help to have the window down. Just take your time to figure it out so you don’t scratch your door. When you push in the clips, make sure they are perfectly aligned, so you don’t break any.
The Passenger Door
Removal of the passenger door panel is different than the driver’s side. First you have to pop off the door open button plastic piece. You will see a bolt; just remove it with the proper tools. There is another bolt on the bottom of the handrail. Repeat the process similar to the driver’s side.
805Z06 is offline   Reply With Quote
Old 05-02-2011, 09:27 PM   #5
BLACK-10
CF Senior Member
BLACK-10's Avatar
great write up
BLACK-10 is offline   Reply With Quote
Old 05-17-2011, 03:57 PM   #6
gregd
CF Senior Member
I agree! Mine is loose on upper left and I have been wondering how to get it off. Great pix!!
gregd is offline   Reply With Quote
Old 05-17-2011, 04:01 PM   #7
gregd
CF Senior Member
Thx for posting!!!
Old 01-30-2012, 04:20 PM   #8
franman69
CF Senior Member
franman69's Avatar
francis.manzella @francisfmdesign
franman69 is offline   Reply With Quote
Old 12-05-2012, 02:03 PM   #9
Vividz06
Junior Member
Quote:
Originally Posted by franman69 View Post
Thanks mate worked a treat removed each door in about 15 mins with mirror removal aswell
Vividz06 is offline   Reply With Quote
Old 12-07-2012, 03:15 PM   #10
Thrash
CF Senior Member
Thrash's Avatar
There is also a step post at the top under my Deadening-Stereo sticky install, easy to do ...
Thrash is offline   Reply With Quote
Old 06-25-2013, 05:27 PM   #11
kenedds
CF Senior Member
kenedds's Avatar
Quote:
thanks
My driver's side panel squeeks (metallic Squeak) when going over bumps. I am pretty sure it is one of the attachment points for the panel - any suggestions as to how to quiet?
kenedds is offline   Reply With Quote
Old 06-26-2013, 09:15 AM   #12
markcz
markcz's Avatar
You can make sure the screws are tight without pulling the skin.
Or pull inner skin off and put something between pieces that are rubbing.
markcz is offline   Reply With Quote
Old 07-10-2013, 04:04 PM   #13
Sled Driver
Junior Member
The real trick is getting them back on.
Some use a shoestring to pull the metal tabs back on the top of the door panel. I've never done that. Just pay really close attention to where the door panel is when it comes off, then you can re-hang it doing the reverse. It's probably a good idea to replace all the fasteners while you have the door panel off as they tend to get loose pretty easily in my experience.
Sled Driver is offline   Reply With Quote
Old 07-26-2013, 08:28 PM   #14
black.z51.c6
CF Senior Member
black.z51.c6's Avatar
where can you buy those retainers?
black.z51.c6 is offline   Reply With Quote
Old 07-26-2013, 09:29 PM   #15
Sled Driver
Junior Member
Quote:
http://www.clipsandfasteners.com/Sea...x=0&Search.y=0
you need both the male and female. I think you need 2 packages to get both doors done.
Old 07-26-2013, 09:32 PM   #16
black.z51.c6
CF Senior Member
thanks thats awesome
Old 07-29-2013, 05:40 PM   #17
jorgep951
Junior Member
jorgep951's Avatar
thanks for posting
jorgep951 is offline   Reply With Quote
Old 02-23-2014, 01:39 PM   #18
Petrolburner
CF Member
Quote:
How do you do that?
Petrolburner is offline   Reply With Quote
Old 02-23-2014, 06:46 PM   #19
markcz
markcz's Avatar
That was posted as a reply to a question about a squeaky and possibly loose skin, I was suggesting that he check the screws that hold it down before pulling it apart.
Old 02-24-2014, 05:49 PM   #20
Petrolburner
CF Member
Thanks, I fixed my door squeak the other day with a bit of double sided foam where the two pieces meet at the midline.
Reload this Page HELP how to take c6 door panels off?
Tags
2000, 2008, c6, corvette, door, liner, loose, panel, panels, removal, remove, removing, replace, window, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 02:23 PM
Is an aluminum frame safe for the track?? mattsmallett C6 Z06 Discussion 34 07-08-2005 04:31 PM
SAE papers and other stuff (Very long) Runge_Kutta C6 Z06 Discussion 18 05-08-2005 02:29 PM
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 11:23 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
