Quote:
Originally Posted by Spkrboy
IMO the best method is to use a signal-sensing box to create a remote turn-on lead. Using one of these, the other components turn on/off with the head unit.
Like this one.
Thanks for the lead..
Quote:
Originally Posted by pentavolvo
generally speaking you use a fuse tap and tap the wiper fuse in the fuse box for power but obviouslly this is acc/ignition controlled not radio controlled. Note there are 2 wiper fuses you have to remove the 2ndary cover on the smaller fuse box to the right and its under there.
the red/white wire is always hott its the battery feed
white is the antenna enable signal which may very well stay on for like 10 -15 min after the car turns off like the xm receiver does
i dont have a purple wire on my diagram
i will tell you this that white antenna enable signal also runs to factory amp which may be in deed turnin on the factory amp as well as the antenna module and the sat tuner
Thank you for coming through. That damn thing drove me nuts. Spent hours testing each wire and trying to figure out why there was no remote. That white wire and other purple wire stays on too long after you turn the car off.
I did what you said. I hooked it up to a 10 AMP heater/washer fuse. It did the job perfect.
I am thinking that red wire to the radio, the main one, should be routed differently. I know the factory did this, but it drains lots of power by staying hot and powering the other two wires.
Would it be possible to wire the main HU, red wire just like the remote? Seems like it would save a lot of battery.
Anyways, the hours/whole day of wiring the HU is finished...
