Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-15-2008, 02:10 AM   #1
boardroomjimmy
CF Senior Member
boardroomjimmy's Avatar
Default best way to drive comps
I'm using a jl 300/4 to drive my pioneer 720's in the doors. Should I give each driver it's own channel or bridge the amp for 150x2? The jl has got built in x-overs and seperate gains which would aid in tuning when running all 4 channels, but would I be loosing volume? I would assume the 150 per side would be divided by the x-overs so the mid would recieve the bulk of the power, so by using the amp as a 4channel, the mids would recieve less overall power right? Would it make an audible difference?
boardroomjimmy is offline   Reply With Quote
Old 03-15-2008, 09:45 AM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
If all you're running is the 2 channels then bridge the output of the 300/4 into the crossovers that come with the 720's, you'll be getting 150x2. Component speakers can be fairly power hungry so you may as well use the power your amp has available.
Passive crossovers do more than just separate frequencies and unless you really know what you're doing it's likely the system will sound worse and that you'll damage the drivers by bypassing the crossover.
TheKomoman is offline   Reply With Quote
Old 03-15-2008, 01:36 PM   #3
boardroomjimmy
CF Senior Member
The 720s have the ability on the x-overs to run bi-amped (seperate inputs) so I was planning on using the x-overs in that manner. Setting the hi pass on the amp for the tweeters and tweaking the output would allow me to further tune the pair. I do have an alpine pdx 2x150 that I could also power them with, I'm just not real impressed with the s.q. I didn't realize it was a class d until I'd bought it. To me the jl is warmer and may play louder, it definitely has a different sound. Would it matter if I placed the X-overs back with the amps instead of in the doors? That would allow for some expirementing. Thanks for the input.
Old 03-15-2008, 04:45 PM   #4
TheKomoman
CF Senior Member
TheKomoman's Avatar
Placing the crossovers by the amps for just those sorts of adjustments is very common, and I think would be a good idea for your situation. You may get better sound quality using the bi-amp setup like that, but you may also find 75 into those midbasses a bit weak. It's enough to drive them, but may not be enough to drive them HARD, depending on how you listen. So since you have the option of placement like that, I'd say to do exactly what you proposed, listen to it both ways and let your ears decide.
I agree with you on the PDX sound. I replaced the 4.150 I was using in my vert with an Xtant x604 for exactly that reason.
Old 03-17-2008, 11:45 AM   #5
CraigE
CF Senior Member
CraigE's Avatar
"Passive crossovers do more than just separate frequencies and unless you really know what you're doing it's likely the system will sound worse and that you'll damage the drivers by bypassing the crossover."
What else do passive x-overs do ?
In what way will it sound worse ?
I have an Audison LRx4.1k driving Dynaudio Esotec System 342 comps.
Ch A is driving the mids and tweets thru the passive x-over and ch B is driving the midbass actively with the lo pass set at 900 htz.
It sounds good, the only concern I have is that the mid bass is rated down to 40 htz and is getting lower (htz) signal than 40.
I talked with the Audison Tech and he said this is the correct way to configure the amp because it is not bridgable. I am looking into installing
another x-over to correct this and would welcome any suggestions.
CraigE is offline   Reply With Quote
Old 03-17-2008, 11:50 AM   #6
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
depending on the x-over it could also have filters built into them such as notch filters or zobel filters. I wouldn't doubt that your dyn's have a zobel built into them.
scott_fx is offline   Reply With Quote
Reload this Page best way to drive comps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
