Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2008, 09:34 PM   #1
orlando_krash
CF Senior Member
Send a message via MSN to orlando_krash
Default Help with installing Avic Z2 on 08 Z06
Hello all,
A couple of quick questions please:
1. What do I need to get to keep my steering wheel buttons functioning with the new Avic Z2
2. Can I keep any of the stock GPS/XM antennas to run my new GPS and Sirius Radio?
3. What is the wiring harness for an 08 Z06 with Nav/OnStar as base audio?
4. Is there finally a good fix for the GPS on an Avic Z2 to operate the GPS while driving? I've heard of so many different opinions that I don't know what is true anymore including the Avic forum. My production date is Sept 2007.
Any suggestion on vendors for install parts would also be much appreciated.
Thank you for any help.
Mike
orlando_krash is offline   Reply With Quote
Old 02-19-2008, 08:12 AM   #2
TheKomoman
CF Senior Member
St Jude Donor '13
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
Originally Posted by orlando_krash View Post
Hello all,
The PAC SWI-PS will get that done.
You can use the stock XM antenna for your Sirius module, but don't expect great reception anywhere near trees. However unfortunately because of the fiberglass bodies this is also true of using the antenna that will come with the unit.
I've never seen where the stock NAV antenna can be used. I suppose if you could track down the wires and attach the standard screw-type connector to it then it would be possible, but I've never seen a report. Mostly I think because it's pretty easy to stick the antenna you'll get with your unit under the dash by the center dash speaker so people don't bother.
The Peripheral GMAH24B or the Metra GMOS-04. Jimmy2Times has reported that the GMOS-04 has the VSS and reverse wires in the harness and that would be very handy for your install.
Mike
Can't offer you specific help on the AVIC, sorry. In case you haven't seen it, here's a link to NOMAD's D2 install, which will cover a lot of what you'll do with the Z2:
http://forums.corvetteforum.com/show....php?t=1518095
TheKomoman is offline   Reply With Quote
Old 02-19-2008, 12:05 PM   #3
Dogue
CF Senior Member
Dogue's Avatar
The GMOS-04 does have the VSS and reverse wires and makes for a pretty easy install. You may need to add a relay to the amp power (I did with my D3) but Metra's service can walk you thru that.
The GPS does function while your driving. If your wanting to search while moving you just follow the steps on Avic411 (move yellow prong, ground parking brake, etc) and you can control everything while moving.
Good luck!
Dogue is offline   Reply With Quote
Old 02-19-2008, 02:12 PM   #4
orlando_krash
CF Senior Member
Thank you very much to TheKomoman and Dogue for your quick responce and helpful information.
I will check our Avic411 again.
thanks.
Mike
Reload this Page Help with installing Avic Z2 on 08 Z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
