Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2008, 10:24 PM   #1
rcmigpilot
CF Senior Member
rcmigpilot's Avatar
Default How do I wire 2 4 ohm subs to show the amp 2 ohms?
I'm confused about the whole series and parallel thing when it comes to speaker wiring. I have 2 8", 4 ohm, SVC subs that I want to run with a sub amp that is rated for 400 watts at 2 ohms. How do I connect the subs? Is it A) pos box connector to sub 1 pos, sub 1 neg to sub 2 pos and sub 2 neg to neg box connector or B) a separate wire from each post of the box connector to the corresponding posts on each sub.
rcmigpilot is offline   Reply With Quote
Old 02-12-2008, 10:49 PM   #2
Kale
CF Senior Member
Kale's Avatar
parallel. JLaudio's website has some great info on this, or BCAE1.
Kale is offline   Reply With Quote
Old 02-12-2008, 10:51 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
is the way
pentavolvo is offline   Reply With Quote
Old 02-13-2008, 08:43 PM   #4
KenHorse
Obama Must Go
St. Jude Donor '11
Support Corvetteforum!
KenHorse's Avatar
Location: Aurora, OR by way of Maui..... The Obama Regime is The Most Dishonest, Corrupt And Criminal In US History©
Quote:
Yup. Paralleling two 4 ohm speakers results in a 2 ohm load.
KenHorse is offline   Reply With Quote
Old 02-13-2008, 10:12 PM   #5
Jimmy 2 Times
CF Senior Member
unless they are dual VC subs.....
Jimmy 2 Times is offline   Reply With Quote
Old 02-13-2008, 10:23 PM   #6
Fasthotrod
CF Senior Member
Fasthotrod's Avatar
UnderRADAR
Send a message via AIM to Fasthotrod
If you would like to learn about it, I'll try to explain it here.
Think of the amp/wiring as your house plumbing. The voltage is the water pressure. If no water flows, no work is done. Now say you hook up a "4 ohm" water nozzle. Water flows (current) and you get your plants watered. Simple, right?
Need more water, just add more nozzles. (parallel) In an electrical connection, + is connected to + while - is connected to - for a parallel connection. More current can flow from two speakers (nozzles) this way.
If you were to wire them in series, it would be + to - to + to - across the speakers. You send 1/2 the "pressure" to each speaker.
Does this make sense to you, or would you like more clarification?
Mark
Fasthotrod is offline   Reply With Quote
Old 02-14-2008, 11:35 PM   #7
thatdood
CF Senior Member
thatdood's Avatar
thatdood is offline   Reply With Quote
Reload this Page How do I wire 2 4 ohm subs to show the amp 2 ohms?
Tags
4ohm, ohms, separately, subs, wire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
