Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-30-2001, 07:56 PM   #1
Kale
CF Senior Member
Kale's Avatar
Default No bass above 80hz??
I finished swapping the Audiobahn for the Xplod
Ive listened to pretty much low-bass songs so far. Mixalot, Godsmack, etc. The bass was LOUD on each one. But now I put in Mudvayne, and the machine gun bass is GONE. And even the Blue song has no kick to it. I didn't change crossovers or anything...
Kale is offline   Reply With Quote
Old 11-30-2001, 09:53 PM   #2
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
Default Re: No bass above 80hz?? (Smash)
this is off topic but....
I love what you put under your post count! :D
RPOZ4Z is offline   Reply With Quote
Old 12-01-2001, 12:13 AM   #3
Zdamon1
CF Senior Member
Send a message via AIM to Zdamon1
You swapped a Sony Explode amp in the place of an Audiobahn??!?!?!?! :confused: :nono:
That is your mistake. Sony car audio stuff sucks....The audiobahn should stomp that speaker. And the Sony's have a bad habit of doing what their name inplies, EXPLODING...
If you are getting no low base, where do you have the crossover set at?? Also so you have the filter on the amp set to LPF?? IF it is on HPF you will get only highs......
Well if you have any other questions let me know.
Just a helpful hint, do some research before you throw out good equipment.
Damon
[Modified by Zdamon1, 9:26 PM 11/30/2001]
Zdamon1 is offline   Reply With Quote
Old 12-01-2001, 12:27 AM   #4
Kale
CF Senior Member
Kale's Avatar
Default Re: No bass above 80hz?? (Zdamon1)
soundstream amps.
audiobahn 210 piston sub. i replaaced it with an xplod sub.
The channel im using is actually "sub only" iu think it is 70hz
[Modified by Smash, 9:27 PM 11/30/2001]
Old 12-01-2001, 12:32 AM   #5
Zdamon1
CF Senior Member
70 Hz Shouldn't be the problem. It is definitely your equipment.
I can get you set up with some stuff if you want.....Let me know.
Damon
Reload this Page No bass above 80hz??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
