Age 50 + : can you hear the difference between CD and MP3?
This question is for the 50+ age group. Can you hear any difference between a CD and an MP3, same selection? Is if high frequency attenuation or is there more? I can't hear over 10K Hertz, so it may not matter.
Yes. It's mostly in the high-frequency detail and subtlety - it depends on the MP3 compression being used.
I'm 52. Not only can you hear it, but once you do with well-recorded CD's and top equipment - you won't go back. Same for the difference between CD and vinyl - then again you probably won't be playing records in your Vette.
Cruise-In VIII Veteran
At 320kps, I have a hard time telling the difference. To my ear (and likely only to my ear!), 192kps is an acceptable compromise between smaller mp3 file size and high enough quality in an automotive cockpit environment -- I find that in the car, at 192 kps I don't often notice that it is only "near CD quality" sound.
Are you saying that with good equipment, MP3 is ok?
However, 320 kbs data compression is pretty darn good. To hear the artifacts at that level of data compression requires the very very best equipment in addition to very good ears. At 192 kbs, it is still better than most stereo speakers can reproduce, though it will be noticeable with good headphones. At128 kbs, the artifacts are so severe that they're very noticeable, even in a noisy car.
I can hear the difference between the cassette player in my '96 Impreza and the base (not Bose) single-CD player in my '07 A6 coupe.
Also, the A6 coupe is faster on dry pavement than the Impreza, which is saddled with 2.2 liters turning an A4, although the Impreza will run rings around the Vette in snow, dirt and beach sand.
I think there is a huge difference. Especially in the highs. The Mp3's IMO, get very tinny and the soundstage seems to get a bit more destroyed.
YIKES!!!! Excellent post.... I thought I was the only that thought vinyl has the absolutely best sound.
I have several absolutely pristeen copies of several Chicago albums on vinyl, I have copied them to my HD in wav files, and the difference between those and the equal version of the MP3 is Night and Day(so to speak)
My vinyl copy of "I'm A Man" literally has me on stage with the band. Incredible layout of each instrument across the car. The MP version is nowhere near that good.
So yes, they are not as good, and I am well over 50....
OK, now if a CD music file is 100 megs (a long classical piece), how many megs would it be at 320kbps? That will tell me how big of an MP3 player to get.
My best guess is that a 100 meg file will compress to 30 to 35 megs when recorded at 320. Anyone else agree? It still depends on the content of the original piece.
MP3 gives you much better quality esp. if you rip it at a higher bit. I don't have the stock audio system and use the new Alpine head unit which is made esp. for the IPOD.
When at home if I have it on vinyl that's numero uno as you can't beat the sound stage.
A quick check shows that I get about 1 hour of 320 CBR in 135MB. I find 192 is the break point for me to tell the difference in music on the Bose system while voice can be indistinguishable down to 96 or less. In general, vinyl also can be the same at much lower rates than CD. But it all depends on the source and even more importantly, the compression program used. The MP3 standard defines how to play the file but it does not define how to compress the music. Therefore there is a BIG difference between compression programs. The difference is bigger than the difference between a low end stereo and a megabuck unit. The Beatles tapes from 1958 can sound great at 48BPS if encoded with LAME but you could probably still hear differences at 192 if encoded with ITunes or Windows Media Player. Bottom line is just like "what will it cost for a stereo that sounds good?", there are a lot of variables other than price or bit rate.
You can't make a blanket statement about MP3 quality. There are too many variables. Bit rate, CBR vs VBR, what encoder was used, what type music, etc.
All that said can anybody really tell me that they are going to be able to critically listen to the level required to hear the difference in a moving car with all the ambient road noise? Maybe some will, but I'd venture to say that it's only going to make a difference to me if I'm listening on my home sound system where I have much better speakers and a much much better listening environment. There I will say that I will usually be able to tell a slight difference between the CD and a well done MP3.
That is all ...
That is all ...
If you are over fifty and can hear the difference, you haven't been playing them LOUD enough! Have you forgotten the James Gang advice that R&R is "made loud to be played loud"? I can't tell the difference in audio quality of DVD audio from an 8 track. It's just loud from five places, not two.
1 Post
Short answer is yes... depending on the playback equipment... On a very detailed revealing system... MP3's sound terrible. In the vette.. you can still hear the difference... but it's acceptable..
