Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-30-2007, 10:17 AM   #1
moserbe
CF Senior Member
Support Corvetteforum!
moserbe's Avatar
Default Removal of OEM stereo
Can someone provide me with instructions to remove the OEM radio?
moserbe is offline   Reply With Quote
Old 11-30-2007, 11:16 AM   #2
TheKomoman
CF Senior Member
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
Since you appear to have 2 Vettes of different generations, you might want to specify which one you're asking about.
TheKomoman is offline   Reply With Quote
Old 11-30-2007, 11:34 AM   #3
Kale
CF Senior Member
Kale's Avatar
c4: undo all visible screws, pull panel off, a couple bolts/screws hold in the radio.
c5: undo the 4 10mm nuts, 2 found under the armrest, 2 found under the little trim panel that usually has the traction control/ride control on it.
3 screws, one under the little vent thing to the left of the ignition, two in the ash tray area. Push the arm rest/box assembly back and up, slide out the center console. Lots of wires to disconnect.
undo the 4 bolts/screws holding radio in. 7mm socket required. some kinda torx too.
Kale is offline   Reply With Quote
Old 11-30-2007, 12:25 PM   #4
1Harley 1Vette
CF Senior Member
As much as I dis-like referring people to the FAQ but I guess this time I myself will have to. If it's a C-4 there is an excellent link for removing the head unit in a C-4. Check it out. One of the best articles on head unit removal I've ever seen. There was one thing missing in the article at least for my CE. I had to remove the 4 screws holding the center console lid on. I had to remove it in order to get the shifter bezel off. When you do that, be careful because there is wiring attached to the back of the console lid to support the light in there.
1Harley 1Vette is offline   Reply With Quote
Old 11-30-2007, 01:52 PM   #5
moserbe
CF Senior Member
moserbe's Avatar
Sorry guys and gals, I should have been more specific. It's the C5 that I'm asking about.
Old 11-30-2007, 01:57 PM   #6
Kale
CF Senior Member
Kale's Avatar
refer to my post, instructions for both.
Old 11-30-2007, 01:58 PM   #7
moserbe
CF Senior Member
moserbe's Avatar
Quote:
Thanks for the info.
Reload this Page Removal of OEM stereo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 04:33 AM
C6 FAQ audio - look here first! Steve Germany Audio/Electronics 24 09-04-2008 11:05 AM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Want to replace C5 Factory unit with MP3 player - advice needed BAD. Venger Audio/Electronics 20 07-17-2002 01:46 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
