Speaker boxes for a C3
Above are some pics of my first endevor into fiberglass, It didn't turn out too bad. It had 2 pair of 6.5s in it and the amp was mounted on top. It was light and strong as hell, but alas the c3 won, it's impossible to get good sound outta a c3. It was a lot of fun building the box though, just use your imagination.
Former Vendor
St. Jude Donor '08
I'm helping a friend build a sub setup for his 72. I'm planning a completely removable setup using an aftermarket cargo storage bin that will hold the amp and low-profile sub. It will have quick releases on the power/ground/speaker wires. Build to come in early '08
When I bought my 78 pace car it had a box w/ 2 M&M 8's that spanned the hatch area above the wheel wells with room to slide the tops under. ONE WORD OF CAUTION::::: the gas tank is directly behind the hatch back panel. You only have about 1" till you hit it. The guy I bought it from said for some reason he can't fill it past 1/2 tank without smelling gas. DOH!!!!
