Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-20-2007, 01:05 PM   #1
carbuff
CF Senior Member
Send a message via AIM to carbuff Send a message via Yahoo to carbuff
Default DNX7100 - how to enable the "Sat" source button?
I thought I read that there was a trick to this before, but I can't seem to find it.
I just pulled my dash apart again to connect the GXM30 antenna wire (grumble, somehow I missed this the first time...), and it appears to be enabled now (I can get stock prices from the NAV menus). However, the "Sat" button on the main source screen does not appear. Is there a setup option that I haven't found to enable that button? And if not, how the heck do I get to my XM Radio stations?!
Thanx for any advice!
carbuff is offline   Reply With Quote
Old 10-20-2007, 01:14 PM   #2
30MilesOffshore
CF Senior Member
30MilesOffshore's Avatar
You have to set-up the menu to enable the NAV button.
Go to:
1) Setup Menu
2) AV Interface
3) Go to page 3 (top right green arrow button)
4) Look near bottom of page and turn on "Navigation Source"
30MilesOffshore is offline   Reply With Quote
Old 10-20-2007, 01:17 PM   #3
30MilesOffshore
CF Senior Member
Sorry, disregard that previous post. I thought you were talking about enabling the NAV button and not the SAT button. The NAV icon didn't appear when I first installed mine and I had to enable it.
Old 10-20-2007, 01:26 PM   #4
30MilesOffshore
CF Senior Member
I do not have the GXM30, but had the terk/kenwood direct hook-up. So mine is a little different than yours. I believe that since you have the Navitraffic, the only way to look at your channels is to go through the GPS Navigation screen.
-- Push the Nav button (not the Nav icon on the screen, but the NAV button on the bottom row).
-- Once you pull up the Navigation system, select TOOLS, and then select XM.
-- This will pull up your Radio ID and you should be able to then setup your account, stocks, weather, etc.
Old 10-20-2007, 07:03 PM   #5
carbuff
CF Senior Member
Thanx 30,
Well, I got the XM working. And as best as I can tell, there is not going to be any Sat button on my main Source panel. To get to the XM controls, it seems you must (as you said) go through the Nav system. :\
One thing that is kinda nice though. By enabling the Nav source button, I can at least hear the audio for the last XM channel I was tuned to. It doesn't take me to the XM control screen, but since 98% of the time that I listen to XM I am listening to 1 station, that is almost good enough.
Thanx for the help!
Reload this Page DNX7100 - how to enable the "Sat" source button?
Tags
2005, button, direct, dnx7100, enable, hear, radio, sat, satsource, vette, xm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
