Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2007, 10:46 PM   #1
5W0P3
CF Senior Member
5W0P3's Avatar
Send a message via AIM to 5W0P3 Send a message via Yahoo to 5W0P3
Default My DNX7100... finally got here!
After tracking down FedEx today, i got my DNX7100... I'll add pics to the first post, but so far... this is all I have. Should be a good setup! Install is going in tonight!
Head Unit:
Kenwood DNX7100
Amp
JL Audio 500/5
Speakers
Focal Polyglass 6.5 Components (Doors)
Focal Polyglass 5.25 Coax (Rear)
Sub Woofer
JL 8w3 or 8w7 in a forward firing ported box. Probably fiberglassed into one of the corners. This part is not in concrete.
QUESTIONS I HAVE RIGHT NOW
1. Do I just not hook up the Parking Switch Wire to access the nav and play DVD while moving?
2. Where is the reverse wire on a C5 to use for back up camera?
5W0P3 is offline   Reply With Quote
Old 10-19-2007, 10:54 PM   #2
C6XTACY
CF Senior Member
C6XTACY's Avatar
What size is your sub?
You should really put up pics of the sub install. The JL stealthbox is way too expensive.
C6XTACY is offline   Reply With Quote
Old 10-19-2007, 11:21 PM   #3
Hawk07
CF Senior Member
Hawk07's Avatar
No reason to hook up the parking brake wire. Last I heard the budget for the "parking wire" cops was cut.
I read others have run straight back to the tail lamps for this hook up. I would think you might be able to find it in the passenger side foot well where the fuse box and wires are though.
Where did you put the rear camera?
Hawk07 is offline   Reply With Quote
Old 10-19-2007, 11:52 PM   #4
MR.WaynesWorld
CF Senior Member
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Support Corvetteforum!
MR.WaynesWorld's Avatar
Location: The real question is; When you turn your car on, does it return the favor..
Send a message via MSN to MR.WaynesWorld
MR.WaynesWorld is offline   Reply With Quote
Old 10-20-2007, 02:51 AM   #5
WHT
CF Senior Member
WHT's Avatar
Hi 5W0P3,
Hope the install is going well. I took the console/bezel out tonight and will do my install on Saturday.
You can simply ground the parking brake wire if you want. The parking brake wire is grounded when the parking brake is engaged.
I believe the reverse wire (receives power when in reverse) is primarily for the backup camera.
WHT is offline   Reply With Quote
Old 10-20-2007, 04:49 AM   #6
5W0P3
CF Senior Member
5W0P3's Avatar
Quote:
Originally Posted by WHT View Post
Hi 5W0P3,
Where are ya'll mounting the Nav antenna? Mine was just under my console in the garage and was picking up full signal!
Also, i stuck a DVD in just to see it, and it starts playing, but can't see any video. Guess i'll have to read the owners manual.
As of 2:48am.... 5 hours later i believe.
Old 10-20-2007, 04:51 AM   #7
5W0P3
CF Senior Member
5W0P3's Avatar
Sub will be an 8" sub.
Old 10-20-2007, 10:46 AM   #8
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
ground the parking break wire and reverese wire unless you have a backup camera isnt needed. if you do have a backup camera running to the reverse light is the easiest place to go. Also just curious how are you mounting your radio in the dash.
As far as getting sound but no display click one of the buttons in the lower right i beleive something like v.select and it will change the video display
pentavolvo is offline   Reply With Quote
Old 10-20-2007, 12:09 PM   #9
5W0P3
CF Senior Member
5W0P3's Avatar
Quote:
I do have a backup camera, so now i have to figure out which light goes off that. I saw someone on a c6 just went to a fuse panel and put in a "add a fuse" kinda thing with a lead on it, that looked pretty easy.
As far as mounting it, i found some corrugated "L" brackets in my tool box and it was like they were made to fit. The radio comes with a pretty good size of black plastic trim ring they say is for GM's, but I don't think they intended it for this GM
Hopefully if all goes well, this is done today.
The back up camera has the same wire as the radio as far as reverse lights, do they both get hooked to the same wire?
I think the parking needs to be grounded for it to work. I'm working on it again right now.
Old 10-20-2007, 12:40 PM   #10
WKMCD
CF Senior Member
WKMCD's Avatar
i got my DNX7100...
Been there - done that.
Good Luck!
__________________
"The Gentleman's Cruiser"
VA Speed 427 - 577RWHP/530RWT WCCH Stage 3 L92 heads and a little baby cam Trans/Diff by RKT56.com
WKMCD is offline   Reply With Quote
Old 10-20-2007, 01:34 PM   #11
5W0P3
CF Senior Member
5W0P3's Avatar
^^^ Yep, thats a 7100!
Old 10-20-2007, 03:49 PM   #12
5W0P3
CF Senior Member
5W0P3's Avatar
For the reverse camera, there is a green wire and a black wire, do I hook the reverse lead from the radio and the Camera to the black wire?
Old 12-18-2007, 03:54 AM   #13
805Z06
CF Senior Member
805Z06's Avatar
805Z06 is offline   Reply With Quote
Reload this Page My DNX7100... finally got here!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
