Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2007, 12:07 PM   #1
black_771
CF Senior Member
black_771's Avatar
Default Very Basic HOWTO - Get rid of "SYS" for aftermarket stereo
This may be somewhere around here already, but I finally fixed the flashing SYS light caused by my aftermarket stereo. All told it was about a $5 project.
Supplies needed:
Heat shrink tubing that fit over 20 gauge wire
One red Male quick disconnect (yes this one is blue, you need the red one)
Click the image to open in full size.
One blue "T Tap"
Two "1k, 1/2 Watt" resistors (Radio Shack)
Assembly
I did the easiest thing I could fine, but it still required cutting the factory harness.
I first took the red quick disconnect and the two resistors and crimped them together. The red disconnect is for 20 gauge wire but the leads on the resistor are much thinner then that so both leads will fit inside the crimp of the disconnect with no problem. Both resistor should be sticking out of the disconnect when finished like a 'Y'.
I then cut the GRAY/BLACK STRIPE and the PURPLE/WHITE STRIPE wires from the factory harness and stripped the ends about 1/2 inch. I put 1 piece heat shrink tubing over each of the wires. The tubing should be long enough to cover the splice we are about to make plus resistor completely all the way to the crimp on the disconnect. This makes it a little nicer and less likely to short out something.
Then twist one wire to one of the resistors and the other wire to the other resistor. You can solder if you want, but I don't think a butt connector will crimp well to the thin resistor lead. I just twisted them together.
I pushed the heat shrink tubing over each assembly from the wire splice all the way up to the end of the disconnect and heated it. I think this creates a pretty good connection.
Last is to crimp the "T Tap" onto the red power lead. Make sure the tap is within about a foot of the radio. The wires that you spliced eariler aren't very long. Anyway this is an ignition switched power connection. Once you crimp the tap into place just plug the disconnect into the T-Tap and you are done.
Hopefully there is no SYS light after this.
black_771 is offline   Reply With Quote
Old 10-10-2007, 12:19 PM   #2
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
See C4 audio FAQ.
Vis Croceus is offline   Reply With Quote
Old 10-10-2007, 12:33 PM   #3
black_771
CF Senior Member
black_771's Avatar
Quote:
Originally Posted by Vis Croceus View Post
See C4 audio FAQ.
Read it. Technical diagrams work for some, step by step works for others.
If this is helpful, then great. If it gets buried, that's fine too.
Reload this Page Very Basic HOWTO - Get rid of "SYS" for aftermarket stereo
Tags
aftermarket, c3, corvette, resistor, stereo, sys
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
