1994 bose replacement/wiring diagram
new here and in need of advice on installing aftermarket stereo in a 1994 vette, I am replacing my bose system and installing a new system(HEAD UNIT AND SPEAKERS) I have run 14 guage wire to speakers but need advice on wiring new head unit, constant hot,ignition,illumination and ground wires any advice would be great Thanks
Read to FAQ sticky at the top of the section, should tell you all you need to know. If you have any other questions, then just ask.
Good luck
Good luck
here is how I wired the new system,memory wire to cigar lighter(red),I used a fuse extender and hooked it to fuse box (radio fuse)for ignition wire,antenna wire to stock plug(gray wire) and for the ground it also went to the cigar lighter . My stereo does not have a dimmer, If anyone knows of a problem that I my have please post
I used a antenna extension to hook up the antenna (LET ME CORRECT ONE THING) I used the pink wire for my antenna not the gray wire as stated in my previous post
