C5 coupe antenna wire
I'm wiring in my kenwood 7100 and am trying to figure out which one of the dark Green wires do you connect the +5 volts too to connect the rear antenna. The Big connector or the small 3 wire connector.
Thanks.
Greg
Thanks.
Greg
Greg
All that is needed is the 12V Green wire. I had done both the 12V and 5v signals to the antenna amp but found that with the 5V off (not applied) I got better reception. In order to get AM the 5V needs to be off also.
Give me a call tonight if you still need help with this.
Gary
Gary
