Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-22-2007, 04:04 AM   #1
Black$heep
CF Senior Member
Black$heep's Avatar
Default Pioneer Avic D-3 Install (lots of pics)
I just finished my install this past weekend. It took some time, but I think it payed off. I put in a Pioneer Avic D-3, bluetooth, Ipod, and a backup camera. It's late, so I'll just post the pics. I'm too tired for a full write up. I used SEM texture coating to make it match and Krylon Fusion-Satin Black 2421 for the final finish.
SEM Textured paint
http://yourautotrim-store.stores.yahoo.net/semteco.html
Krylon Fusion Satin Black f
http://www.krylon.com/main/product_t...roduct_details
If you have any questions about something I did, ask away.
Click the image to open in full size.
Black$heep is offline   Reply With Quote
Old 09-22-2007, 05:45 AM   #2
Junkman2008
CF Senior Member
Junkman2008's Avatar
Okay, first post in this area of the forum (to which I still can't figure out how to get here...).
It appears that you cut the stock center console opening for the radio and moved part of it down, to make the opening bigger. If that's the case, what did you use to "bondo" up the opening created when you moved that section down?
If you made the radio opening bigger, then the AC unit had to move down. How did you not have to get rid of the ashtray area?
Again, I'm new to this section. Your console looks amazing, just as if it was stock. Great job!
__________________
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 09-22-2007, 09:18 AM   #3
C5 KIDD
CF Senior Member
Cruise-In VI Veteran
C5 KIDD's Avatar
first off... sweet job on the bezel! the finished product looks GREAT! congrats on the new mod and thanks for posting some install pics. enjoy the new setup!!
C5 KIDD is offline   Reply With Quote
Old 09-22-2007, 09:58 AM   #4
Black$heep
CF Senior Member
Black$heep's Avatar
I did cut the center console and move the entire a/c control down about 3/4 ". Some guys just close off the ashtray area, but I desided to use the space for a place for my phone/wallet. I cut the entire ashtray/cig lighter assy out from the back and molded a new compartment. That was as deep as I could go with out hitting the air bag module. I used epoxy resin to mold everything, sanded, bondo for the fine work, sanded some more, added textured coating, and then painted to match. I found that Krylon Fusion-Satin black matched perfect.
I used these.(Wal-mart)
Old 09-22-2007, 10:00 AM   #5
Black$heep
CF Senior Member
Black$heep's Avatar
Quote:
Thanks. That's a great compliment coming from you. I have seen several examples of your work floatng around the forum.
Old 09-22-2007, 10:25 AM   #6
TrumpVette
CF Senior Member
Cruise-In IX Veteran
Support Corvetteforum!
TrumpVette's Avatar
How were you able to determine the new exact position of bracket locations to match up with the bezel? Was it just trial and error or did you take measurements?
By the way, Thats a really nice install.
How did you drill the hole for the rear camera without disturbing the plate light?
Thanks, - Danny -
TrumpVette is offline   Reply With Quote
Old 09-22-2007, 11:12 AM   #7
Black$heep
CF Senior Member
Black$heep's Avatar
Thanks, - Danny -
I reused the removed lower bracket(flipped upside down). I am pretty sure you can just flip the upper bracket upside down and it will be dead on. I used the lower bracket, because it didn't have the bent whole on the back.(needed the space for the bluetooth adapter). I mounted the radio first them pushed the bezel back on over the mounted radio and marked how far down I needed to cut. After cutting, I put the whole thing back in and taped the A/c surround into its new location. A couple dabs of super glue and it was workable. I molded the back first to make it rigid and then stared on the front.
Old 09-22-2007, 12:41 PM   #8
Junkman2008
CF Senior Member
Dude, you're just scary talented. I wouldn't try this if someone held a gun to my head.
__________________
Old 09-22-2007, 07:43 PM   #9
jarda
CF Senior Member
jarda's Avatar
Great work...Very clean
jarda is offline   Reply With Quote
Old 09-22-2007, 11:25 PM   #10
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Great job man
DPG is offline   Reply With Quote
Old 09-23-2007, 09:45 AM   #11
Slow Z06
CF Senior Member
Slow Z06's Avatar
txz0603
werd.
Want to help me do mine
Slow Z06 is offline   Reply With Quote
Old 09-23-2007, 09:29 PM   #12
provp
CF Member
provp's Avatar
Default Pioneer Install
Jeremy, did you connect to your stock Bose system?
provp is offline   Reply With Quote
Old 09-24-2007, 11:02 AM   #13
Black$heep
CF Senior Member
Black$heep's Avatar
Quote:
I tried. I bought the adapters, but still couldn't get the stock subs to power up. I finally ran the stock front tweets and backs right off the Avic D-3. I already had my sub in the back, so I didn't really need the stock subs. It sounds ok, but i think it could sounds way better. I'm going to be putting in some components soon. I just have to decide which ones. I still have the Peripheral SVEN2. I never used it.
Old 09-25-2007, 01:31 PM   #14
Brabus2
CF Senior Member
Brabus2's Avatar
Fantastic job!
__________________
2001 Brabus EV8 Kompressor
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
2009 SL65 AMG (Brabus Tuned)
2012 S63 AMG
Brabus2 is offline   Reply With Quote
Old 09-30-2007, 05:42 PM   #15
NemesisC5
CF Senior Member
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
Great Job on a Great Mod!!
__________________
Scotty
"More is Never Enough"
1999 MN6 Coupe:
"A&A Corvette" Vortech S-Trim Supercharger—ECS Alky—Mamofied FAST 90/LS2 TB—AFR 205s—Comp 220/228—Kooks—Corsa—RPS Triple Carbon—Baer "6s" Extreme Brakes—Pfadt Coil Overs—Hotchkis Sways—708whp/640wtq SAE @11.4psi Pics Here
NemesisC5 is offline   Reply With Quote
Old 09-30-2007, 10:07 PM   #16
provp
CF Member
provp's Avatar
Jeremy, Great Install! Where did you tie into your VSS signal?
Old 10-01-2007, 04:50 PM   #17
Black$heep
CF Senior Member
Black$heep's Avatar
I had the Bose system and I tied into the stock 12 pin harness. The bose uses the speed sensor to raise and lower the volume according to the RPMs. The wire is at the back of the stock bose harness, dark green with a white stripe.
Old 12-31-2007, 03:30 PM   #18
Archdog75
CF Senior Member
Archdog75's Avatar
Do you have a picture of the harness? How is that wire working for you, any problems because some people use the wire behind the custer or wire near the pcm.... Or is it the same wire but easier to get to.
Also, where did you tap for the reverse signal?
Where did you get the right angle attachment for your drill... I went to Home Depot and asked for one, and he acted like he had no idea where I could get one.
If any other tips, that would be great.
Thanks,
Justin
Archdog75 is offline   Reply With Quote
Old 01-02-2008, 09:20 AM   #19
Black$heep
CF Senior Member
Black$heep's Avatar
Thanks,
Justin
The green w/white stripe wire has been working great. I don't have a pic though. I should have taken one when I had it out.( I will next time I have it out)
I know its on the 12 pin stock harness.
I tapped into the backup lights in the back for the reverse signal. I wanted to make sure I got a good signal. I read there are other places, but the more I read the more I got confused and eventually just went with what I knew. I also used that for the back up camera install, worked great.
My brother-in-law gave me the angle grill. He told me be bought it at Home Depot.(could have been a while back, don't know)
Old 01-04-2008, 01:45 AM   #20
DefenderC5
CF Senior Member
DefenderC5's Avatar
I found the 90 degree angle chuck at ACE hardware and Harbor Freight Tools.
EDIT: Its 45 dollars at ACE and 25 dollars at Harbor Freight... I could not tell the difference.
I first bought a trick orbital style chuck that adjusted to other angles as well for 35 dollars from ACE. Although it was pretty neat, it does NOT FIT for this C5 project. So don't waste your money on it like I did.
DefenderC5 is offline   Reply With Quote
Reload this Page Pioneer Avic D-3 Install (lots of pics)
Tags
avic, bezelashtraycig, c5, corvette, d3, install, lighter, pics, pioneer, radio
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
