Quote:
Originally Posted by dvandentop
is it possible in a c6 with the nav to add a 6 disc changer to the unit???
i think it is sorta dumb the c6 nav unit doesnt have a 6 disc implemented in the head unit
I believe it is possible to do this with the GM changer that gets mounted in one of the cubbies. Contact Gene Culley at GMPartsHouse.com. He sells the changer and he should know if it can be done(pretty sure it can be). Also I believe the changer is a 12 disc, not 6.
Stuffing a 6 CD changer into a unit that does NAV too is asking alot from a single device.. there are space limitations to electronics somtimes. Don't think I've seen even an aftermarket NAV that has an integrated changer. Closest thing to that would be the units with hard drives where you can rip music to them directly.
