Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-11-2007, 02:17 PM   #1
Smooth72
CF Senior Member
Smooth72's Avatar
Kevin Lowe
Default Where to Point Tweeters
I am starting to try to figure out how I am going to do my install in my C6 Coupe. I am going to use the JL ZR650-CSI in the doors and you can point or tilt the tweeter. I read somewhere to point them torwards your Dome light since C6 don't have one I wounder if I pointed them torwards the roofs back latch. I figured someone on here has already played with this
Smooth72 is online now   Reply With Quote
Old 09-11-2007, 02:25 PM   #2
Kale
CF Senior Member
Kale's Avatar
generally speaking, point them toward the opposite headrest.
But there could be reflection issues. Toy with them, one day per position, until you find something good. A small change may be the difference in a harsh sound and a good sound.
Kale is offline   Reply With Quote
Old 09-11-2007, 03:43 PM   #3
Spkrboy
CF Senior Member
Spkrboy's Avatar
To be able to choose a position and run with it, you'd have to have information on the off-axis response with your particular crossover in place. Since you're unlikely to have access to that data, incremental changes are the key. Small changes in position, height or angle can make all the difference between a wide presentation or point-source sound. After playing with a C6 for a bit, I can say with no hesitation that the factory mid/tweeter position is not very good, no matter the angle.
Agreed, Komoman?
Spkrboy is offline   Reply With Quote
Old 09-11-2007, 03:54 PM   #4
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
Agreed, Komoman?
Hard to make sweeping generalizations, but my experience so far agrees with ya. It's just too darned close to your ears. Even with my crossovers set to -6db and the treble turned down the tweets become fatiguing.
It's certainly the most convenient mounting location and perhaps with a different tweet, crossover or even material folks may get different results. But absolutely I agree with taking your time, making small changes and letting your ears tell you what sounds best.
TheKomoman is online now   Reply With Quote
Old 09-12-2007, 02:09 PM   #5
Smooth72
CF Senior Member
Smooth72's Avatar
Kevin Lowe
Thanks.
Old 09-14-2007, 11:38 AM   #6
ArrogantZ
CF Senior Member
ArrogantZ's Avatar
Let us know what results you get
ArrogantZ is offline   Reply With Quote
Old 09-14-2007, 02:38 PM   #7
Smooth72
CF Senior Member
Smooth72's Avatar
Kevin Lowe
It will be a while. I have to build my Sub box and amp mounts first.
This is what I am going with.
JL ZR650 CSI Front
JL XR650CSI Rear fill (I know some don't like, I do)
JL 450/4 AMP
JL 500/1 AMP With remote
JL 10W7 SUB
....and lots of sound proofing.
They all look great on my work bench, Especially the ZR 650 and the 10w7.
Too bad other responsibilities get in the way, wife teenage daughter, house
Old 09-15-2007, 04:43 PM   #8
ArrogantZ
CF Senior Member
ArrogantZ's Avatar
JL ZR650 CSI Front
JL 450/4 AMP
JL 10W7 SUB
No your responsibilities are your car and this forum now install that stuff and give us the results
Old 09-15-2007, 10:47 PM   #9
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
Quote:
Reguarding the tweeter aiming, from what I can tell you have dome style tweeters which means tweeter aiming isn't as important as tweeter placement. IMO a place you should look at are the bottom corners of the windshield. This is a good spot for raising the soundstage. If I remember correctly the C6 has much higher mounts for the tweeters than a C5 so as long as your tweeter has a good line of sight to your ears, you should be fine. You may want to consider mounting them on a small pedistool (3/4" MDF?) to make sure the sound clears the door panel clearly.
TheRadioFlyer97 is offline   Reply With Quote
Reload this Page Where to Point Tweeters
Tags
c5, corvette, placements, point, pt410f3, tweeter, tweeters
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
Stuck... where oh where 5.1 brianw21 Audio/Electronics 10 11-23-2002 05:53 AM
Nice Stereo upgrade for only $19.95 Turbo5 Audio/Electronics 99 06-30-2002 05:05 PM
Has anyone installed flush mount tweeters in the front pillars of a C5? y2kylwc5 Audio/Electronics 11 06-17-2002 11:47 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
