Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-09-2007, 02:23 PM   #1
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
Default Amp repair Qs for late C4 Bose
Re: `91 coupe
One of the rear amps blew (sounded like a gunshot) a few months ago, and now one of the fronts is going out.
On the rear amp, I can clearly see where, I believe it's a transister, is scorched.
It's "Q1" on this sites diagram. http://www.zr1netregistry.com/Bose2.pdf
I was able to remove it, and I want to see if a replacement will fix it. However I'm having trouble finding the correct replacement transister.
I can't find a match on the original manufactures site. http://www.st.com/stonline/
I think I found a matching one on this site, http://www.digikey.com/
But I don't know if it's the 55v or 60 volt version.
As for the front one, since I can't see any damage, I'm thinking of putting it back in and letting it die completely to find out what part needs replacing.
Any help is appreciated.
Z-07 freak is offline   Reply With Quote
Old 08-09-2007, 04:53 PM   #2
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
I have some at home.. I would need to check the #, I might even have the receipt from when i ordered them.. Not sure i will get a chance tonight but I don't think it should matter on the 55 or 60v part
-=Jeff=- is offline   Reply With Quote
Old 08-09-2007, 05:34 PM   #3
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Between the 55v and 60v parts just get the higher one.
Didn't look at the links so I'm not saying either one is actually correct...
Vis Croceus is offline   Reply With Quote
Old 08-10-2007, 12:15 PM   #4
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
I guess I'll try the 60v and see if it works.
http://www.digikey.com/scripts/DkSea...IRFIZ24EPBF-ND
Reload this Page Amp repair Qs for late C4 Bose
Tags
55v, amp, bose, c4, repair, stereo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
