Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-08-2007, 12:41 PM   #1
johnnymo63
CF Senior Member
johnnymo63's Avatar
Default Dead Antenna 94 Coupe
My antenna has not worked since I bought the car. It's in the down position. I searched for the antenna relay, but can't find it. Does it even have one?
What's the best way to remove the antenna? My Helms Manual says to take out the rear speaker to get access to it, but the body panel is there.
__________________
94 Vette / 86 Pace-Car / 84 Vette / 63 Nova
My 84 Vette Resto Thread:
http://forums.corvetteforum.com/c4-g...84-2-tone.html
Early vs Late Comparison (84 & 94):
http://forums.corvetteforum.com/c4-g...omparison.html
C5 Brake Upgrade: http://forums.corvetteforum.com/c4-t...done-pics.html
johnnymo63 is online now   Reply With Quote
Old 08-08-2007, 11:17 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
well... it's a bitch.
1. jack up and remove LR wheel.
2. Remove inner fender liner.
3. look at antenna and marvel that some ass-hole thought this was a good idea.
4. remove harness connector (I don't remember if this is here or inside the car)
5. inside car, open hatch
6. remove left gas strut.
7. cuss that this takes so many steps.
8. remove trim panel and LR speaker.
9. pull back carpet, look for antenna harness. disconnect.
10. remove grommet that seals the harness for the antenna.
11. back under car, marvel that some ass-hole thought this was a neat idea.
12. remove bolts that hold antenna to body. 10mm, IIRC.
13. remove castle nut holding antenna to bodywork.
14. remove grounds to chassis.
15. have a beer, cuss some more, cause you have been at it for nearly 2 hours and still haven't acquired a sence of accomplishment.
16. reverse process to install new one.
It's something like that... real close at least.
bogus is offline   Reply With Quote
Old 08-08-2007, 11:31 PM   #3
Spkrboy
CF Senior Member
Spkrboy's Avatar
Bogus understates it. This is a SERIOUS PITA. I did it twice. Buy the best antenna you can find so you don't have to repeat this torture.
Spkrboy is offline   Reply With Quote
Old 08-08-2007, 11:56 PM   #4
johnnymo63
CF Senior Member
johnnymo63's Avatar
Damn, guys. That's funny.
You think just like I do. I'm not looking forward to doing it, but...
Is there a relay for it?
Old 08-09-2007, 03:55 AM   #5
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
Yes. Mine was in the storage compartment with the CDM but it may move around by year and body style like the CDM did. Check your FSM.
The antenna in my C4 vert is easier to get to than any other car I've worked on the antenna on. Most of them required contorting your hands into tiny spaces in the trunk or hatch with lots of sharp edges and sheet metal screws to cut you, and then working by feel because you couldn't see anything.
Vis Croceus is offline   Reply With Quote
Old 08-09-2007, 12:20 PM   #6
johnnymo63
CF Senior Member
johnnymo63's Avatar
My manual says it's in between the LR speaker and the tail lights. Under the trim, I only saw the ant. connector. I'll pull the antenna out and see if it will operate directly off the battery.
__________________
Reload this Page Dead Antenna 94 Coupe
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
