So, I decided to finally put the MD102s in the a-pillar. I found this position has the least glass reflections, and images ok, though stage width leaves a little to be desired.
Step the first:
Plan out and angle your ring. Used dowels, hot glue, and a toilet paper roll for shape:
And then:
Place a thin cloth around the pillar, to give it shape. Because I had such sharp angles, I had to do this in small increments, a combination of hotglue and crazy glue.
I covered the whole thing, to repair a hole I cut in the bottom, as well as to make leveling easier.
Then, a coat of fiberglass resin. At this point, I decided to NOT lay actual fiberglass, because of the shape and low strength needs. I sanded between coats, and did a second layer of resin, providing adequate strength.
Next came bondo filler. Never used it before. Wishing I never had to again. Put that in, and started with 80 grit, up to 120 grit on the finish, to level it all out:
Once that was done, I shot it in black primer. Not sure yet if I'm going to texture and paint, or use vinyl.
Looks cool man, certainly better and more functional than the last version, especially from an imaging standpoint. They look about 20* off axis to the driver and I am guessing cross fired to the middle?
Fej
Just about. I tried to keep them around an (eyeballed) 30' off axis, as that is the smoothest response available from the Md102.
I do get some weirdness from the steering wheel, but not too bad. I have to reduce 5k about 2db and they are golden.
I might build some L-Pads to drop them another couple DB, just because I like the tweeters to be more "polite."
1) ROAD AND WIND NOISE MAKES ME ANGRY.
2) Tweeters are still a touch bright.
3) Door resonance, which I'm working on.
4) I started this install December of 2006, and I've been working on it ever since.
Solutions:
1) Rubberized undercoating on EVERYTHING. More Foam. FOam foam foam foam foam. More Foam.
2) L-Pad? Further attenuation.
3) Raamat BXT to replace the crappy edead that's falling off
4) Well... IT might be another year or two
apparently my dumb ass didnt put enough hardner in the bondo on the second pillar, and its still damp 12 hours later. Oh well, maybe the garage heat will "cook" it today.
I'm bad with that stuff... always too much, or too little.
Solutions:
Have you considered somethign like Rhino-Lining? That stuff is dense... and should do wonders to kill road rumble and resonance.
Good luck with the texture and dye. That was one of the hardest things to perfect when we did the monitor in the dash.
We ended up sprat texturing from a distance to get larger globs and then lightly sanding it down to knock the tops off. Looks real damn close.
