Memphis Audio 100.4 amp
Memphis Audio 500.1 amp
Memphis Audio 3 way x over
Memphis Audio MClass 6 1/2" separates (front)
Memphis Audio MClass 5 1/4" separates (rear) (fit perfectly in stock 5 1/4" locations--crossover fit to the rear of the enclosure)
Memphis Audio M3 12" sub
Pac-audio Aoem-vet1
Stock head unit
I finished the install in my car but have a strange issue with the 12V trigger from the PAC interface. I used a standard bosch mini relay which is triggered by the blue wire to provide remote turn on for the 2 amps and the x over. If I turn the car on, and turn the stereo on, the amps and xover will not turn on. If I disconnect the trigger wire from the relay , and reconnect, the amps all turn on. The circuit is getting 12+V. I checked and tested all my soldered connections. I thought it might be a bad relay so I jumped straight to one of the amps, and it did the same thing. I really can't figure this one out..... my next step is to take power from my antenna trigger....and see if that fixes the problem.
