Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-11-2007, 01:06 AM   #1
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
Default MDF or??
Ive got some 1/2 mdf I used to make some templates for the rear 6.5 speakers, I dont have a lot of room to play with as Ive go thte speaker screwed to the mdf and then the mdf screwed to the plastic peice where the stock speaker screwed too.
The problem is with the it in place the speaker now sticks out to far and Im unable to put the cover back on so I need some thinner material, I know that mdf likes to crack close to the edges which is where ive got the screws.
Im not even sure how thing you can get mdf? Is there any other material that would be suitable?
I think 3/8 *should* do it.
clayton1 is offline   Reply With Quote
Old 07-11-2007, 01:17 AM   #2
Kale
CF Senior Member
Kale's Avatar
1/4. Should be fine. If it cracks, put some wood glue on.
Kale is offline   Reply With Quote
Old 07-11-2007, 01:21 AM   #3
Spkrboy
CF Senior Member
Spkrboy's Avatar
Thin MDF is terrible stuff.
Try ABS plastic... 1/4" by itself or 1/8" with fiberglass reinforcement. Unless Komoman wants to part with some canvas phenolic sheet.
Spkrboy is offline   Reply With Quote
Old 07-11-2007, 01:31 AM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
i always use 1/4 for small baffles never a problem
pentavolvo is offline   Reply With Quote
Old 07-11-2007, 01:34 AM   #5
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
Ok, Thanks for the quick replies
Old 07-11-2007, 07:36 PM   #6
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
Well, I just got in from looking for some 1/4" mdf and NO-ONE here has it. Only 1/2 and up.
I guess Ill have to sand down what ive got.
Old 07-11-2007, 11:13 PM   #7
Spkrboy
CF Senior Member
Spkrboy's Avatar
Grab some 1/8" Hardboard and double it up with polyurethane glue (Gorrila Glue). It's better than trimming down 1/2" MDF because MDF is not a consistent material throughout its thickness. As soon as you remove the surface layers, MDF becomes significantly weaker. Hardboard will do fine until you can find a better solution.
Old 07-12-2007, 03:11 AM   #8
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
I ended up sanding down about 3/16 off, and it was still fairly strong, so I used it and it worked well.
Reload this Page MDF or??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fiberglass and MDF - do they get along? Nelson V. Audio/Electronics 12 12-18-2004 08:16 PM
A Bunch or Misc parts, NX Kit, speakers, all kinds of stuff.... Cleaning out the garage... Mike69@ECS C3 Parts for Sale/Wanted 17 06-23-2003 12:47 PM
Wood, Fiberglass or Carbon Fiber? Randy K Audio/Electronics 16 11-21-2002 03:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
