Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-09-2007, 03:00 PM   #1
GotVett?
CF Senior Member
GotVett?'s Avatar
Default Invisacord Install Questions
Getting ready to install my new V1/Invisacord/Vettemod mount in my '07 3LT (autodim mirror) coupe and wanted to ask and confirm a couple of questions of those that have already installed theirs:
1) How exactly does the Invisacord go under the liner and is there room for any excess, if I choose to mount on the drivers side?
2) I have the autodimmer as stated. Does the yellow wire go into the middle Pink lower row switch and the black ground goes into the Black top row switch? I understand it works best if the wires go on top of the existing wires, correct?
3) When taking the screw out of the visor clip, it says there is a sensor in it and to be careful. What sensor?
4) Does the car have to be running as indicated on the Invisacord site?
Thanks for the help and any further tips (even though it's suppose to be fast and "simple".
GotVett? is offline   Reply With Quote
Old 06-16-2007, 10:48 AM   #2
Kreuzen
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12
Support Corvetteforum!
Kreuzen's Avatar
I mounted mine on the passenger visor - just tuk/push the wire up into the area between the windshield/gasket and interior trim molding - it'll just slip right in. Black will go in the top row - 1st slot/just push it in above the existing wire. By pushing the pin in above the existing wire, it will make for a tighter seal/fit. Your hot wire will go into the bottom row, about 4-position, right above the pink wire. Again, this will make for a tighter fit and also power up/turn off your unit only when the car is running--thus eliminating the need to turn the unit on/off. Don't worry about the sensor, its to the left of the visor screw and the bracket will not interfer with its location/operation. I can't recall off had what the sensor is for--interior dimming sensor...but again, not an issue. Piece of cake, should take you about 10 minutes (taking your time) and makes for a very clean, efficient installation.
Kreuzen is offline   Reply With Quote
Reload this Page Invisacord Install Questions
Tags
bug, c5, c6, clip, corvette, install, installation, installing, invisacord, invisacordcomgallery, make, mount, problems, sensor, visor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
